[Qgis-user] WMS layer not working in QGIS
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Tue Dec 10 09:58:50 PST 2013
Hi List,
Before I report this one as a bug I want to see if it's just me.
I'm trying to access the WMS layer from the UK Land registry here:
http://inspire.landregistry.gov.uk/inspire/ows
(note: It only shows when zoomed in closer than 15k.)
This works fine in ArcMap and an OpenLayers client but doesn't in QGIS.
Once I've added the layer (the GetCapabilities is fine) my error log says:
Map request error (Status: 200; Response: �PNG
> ; Content-Type: ; URL:
> http://uatinspire.landregistry.gov.uk/u1c/ows?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=433672.13541449012700468,361044.86458240094361827,437939.86458550987299532,362873.13541759905638173&CRS=EPSG:27700&WIDTH=1613&HEIGHT=691&LAYERS=inspire:CP.CadastralParcel&STYLES=&FORMAT=image/png&DPI=96&MAP_RESOLUTION=96&FORMAT_OPTIONS=dpi:96&TRANSPARENT=TRUE
But that URL works just fine in a web-browser.
Does it work for anyone else? I've tried both 2.0 and the latest weekly.
Cheers,
Jonathan
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131210/e1798c6e/attachment.html>
