[Qgis-user] Fwd: adding a CSV delimited text layer
Chris Crook
ccrook at linz.govt.nz
Thu Dec 12 09:53:07 PST 2013
Hi Marc
The CSV driver has changed and is more rigorous mainly in its handling of quoted fields. So if your CSV file has an umatched quote in the first line then it would treat the following lines as a continuation of that. But normally a CSV export from a spreadsheet would not do that. I'd be very interested to see a copy of the first few lines of your CSV file if you are prepared to zip it up and send it.
Thanks
Chris Crook
________________________________________
From: Randal Hale [rjhale at northrivergeographic.com]
Sent: 13 December 2013 03:32
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Fwd: adding a CSV delimited text layer
What if you specified a custom delimiter and used comma? I'm wondering if something has changed in your file....
Can you share it? or is it sensitive?
Randal Hale, GISP
North River Geographic Systems, Inc
http://www.northrivergeographic.com
423.653.3611 rjhale at northrivergeographic.com<mailto:rjhale at northrivergeographic.com>
<mailto:rjhale at northrivergeographic.com><mailto:rjhale at northrivergeographic.com>
twitter:rjhale
http://about.me/rjhale
On 12/12/2013 08:53 AM, Marc Dupuis-Desormeaux wrote:
HI! first time question. I am pretty comfortable with QGIS 1.8 but have just converted from 1.8 to 2.0.1 and apparently have lost my mind as I can't even upload a simple .csv file anymore. I am using OSX (Maverick). I have created my .csv file using excel in the usual way, by saving it from an .xlsx to a .csv as I've done many times in QGIS 1.8.
The file is simple, the first row has the headings (DATE,SPECIES,AGE,SEX,GPSX,GPSY,COD) the rest is data but when I'm uploading the file QGIS is not reading each line but is treating all data as one long line of headings and therefore is not finding any data.
Help!
[cid:part1.06080006.03060807 at northrivergeographic.com]
Marc
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/qgis-user
This message contains information, which is confidential and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
