[Qgis-user] Fwd: adding a CSV delimited text layer
Joshua Brooks
josh.vdbroek at gmail.com
Thu Dec 12 14:31:24 PST 2013
Interesting. Chris sent me a copy, Linux with 2.0.1 was happy to use it as
it was. There were extra unnamed and blank cols and line endings were CR.
On Dec 13, 2013 3:02 AM, "Chris Crook" <ccrook at linz.govt.nz> wrote:
> Hi Marc
> The CSV driver has changed and is more rigorous mainly in its handling of
> quoted fields. So if your CSV file has an umatched quote in the first line
> then it would treat the following lines as a continuation of that. But
> normally a CSV export from a spreadsheet would not do that. I'd be very
> interested to see a copy of the first few lines of your CSV file if you are
> prepared to zip it up and send it.
> Thanks
> Chris Crook
> ________________________________________
> From: Randal Hale [rjhale at northrivergeographic.com]
> Sent: 13 December 2013 03:32
> To: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] Fwd: adding a CSV delimited text layer
> What if you specified a custom delimiter and used comma? I'm wondering if
> something has changed in your file....
> Can you share it? or is it sensitive?
> Randal Hale, GISP
> North River Geographic Systems, Inc
> http://www.northrivergeographic.com
> 423.653.3611 rjhale at northrivergeographic.com<mailto:
> rjhale at northrivergeographic.com>
> <mailto:rjhale at northrivergeographic.com><mailto:
> twitter:rjhale
> http://about.me/rjhale
> On 12/12/2013 08:53 AM, Marc Dupuis-Desormeaux wrote:
> HI! first time question. I am pretty comfortable with QGIS 1.8 but have
> just converted from 1.8 to 2.0.1 and apparently have lost my mind as I
> can't even upload a simple .csv file anymore. I am using OSX (Maverick).
> I have created my .csv file using excel in the usual way, by saving it
> from an .xlsx to a .csv as I've done many times in QGIS 1.8.
> The file is simple, the first row has the headings
> (DATE,SPECIES,AGE,SEX,GPSX,GPSY,COD) the rest is data but when I'm
> uploading the file QGIS is not reading each line but is treating all data
> as one long line of headings and therefore is not finding any data.
> Help!
> [cid:part1.06080006.03060807 at northrivergeographic.com]
> Marc
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
> This message contains information, which is confidential and may be
> subject to legal privilege. If you are not the intended recipient, you must
> not peruse, use, disseminate, distribute or copy this message. If you have
> received this message in error, please notify us immediately (Phone 0800
> 665 463 or info at linz.govt.nz) and destroy the original message. LINZ
> accepts no responsibility for changes to this email, or for any
> attachments, after its transmission from LINZ. Thank You.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131213/84532b7b/attachment.html>
