[Qgis-user] Problem with intersect polygon and line
Cathomen Carli
carli.cathomen at jzp.ch
Mon Dec 16 02:24:18 PST 2013
Thanks a lot for your help
I managed to do the intersection with den Plugin 'Digitizing Tools'
Regards
Carli
> On 10-12-13 09:28, Cathomen Carli wrote:
>> Hello Forum
>> I am trying out QGIS Dufour and would like to intersect a polygon with a line. (Vector -> geoprocessing -> intersect). Unfortunally the result is not the as expected(=empty layer). Did anybody face the same issue? Am I missing something?
> Hi C,
> I've been testing here:
> - if I use two polygon layers, it just works as you would think it would
> work
> - if I use it with a line and a polygon (as is your question), it only
> works if I use the line as first input layer and the poly as the second.
> The other way around indeed has an empty result.
> if this is still not what you want, plz consider creating a simple
> dataset, with maybe a result or result image you actually want. And
> create an issue in our bugtracker (or ask one of us to do it).
> Regards,
> Richard Duivenvoorde
