[Qgis-user] Region of Select Tool remains (qgis 1.8 Win)
Salvatore Larosa lrssvtml at gmail.com
Wed Jan 9 07:54:40 PST 2013
Hi Agustin,
2013/1/9 Agustin Lobo <alobolistas at gmail.com>
> It seems a bit different, as I do not have any group.
> I've found the problem when using the Select Tool while having a
> raster layer selected instead of
> having a vector layer (by mistake, of course). Hopefully the same
> solution fixes both
> problems, but it would be worth checking (I do not have master).
> Agus
Yes, Larry's patch fixes the issue either way !
Regards,
-SL
> On Wed, Jan 9, 2013 at 2:34 PM, Salvatore Larosa <lrssvtml at gmail.com>
> wrote:
> > Hi,
> >> Sometimes the semi-transparent rectangle drawn by the Select Tool does
> >> not vanish:
> >> http://dl.dropbox.com/u/3180464/select.jpeg
> >> even after refreshing or subsequent selections.
> >> Had not seen this problem on linux or Mac.
> >> Any solution other than exiting and starting up again?
> > known issue [1] and already fixed in master branch !
> > Regards,
> > -SL
> > [1] .- hub.qgis.org/issues/6937
> >> Thanks
> >> Agus
> >> _______________________________________________
> >> Qgis-user mailing list
> >> Qgis-user at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/qgis-user
> > Salvatore Larosa
> > linkedIn: http://linkedin.com/in/larosasalvatore
> > twitter: @lrssvt
> > skype: s.larosa
> > IRC: lrssvt on freenode
Salvatore Larosa
twitter: @lrssvt
skype: s.larosa
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130109/05b8e40b/attachment.html>
