[Qgis-user] Problem with R script in Sextante, I can't write the output
Agustin Diez-Castillo gvsig.mac at gmail.com
Wed Jan 9 06:28:35 PST 2013
Maybe, I'm doing some silly mistake but I don't know where.
With [1] everything works fine, but when I try to write the output to a
shape [2] I got an error (Can't convert columns of class: AsIs; column
names: i_ID,j_ID). Finally, if I write the output with writeLinesShape [3]
I get the shape I'm looking for, before the algorithm crash.
AFAICT "lines" is an object of class SpatialLinesDataFrame
Any ideas?
Thanks
[1]------------------------------------------------
##[datagistips]=group
##points=vector
##neighbours=number 3
##showplots
library("spdep")
mur_coords <- coordinates(points)
mur.knn <- knearneigh(points, k=neighbours)
plot(points)
plot(knn2nb(mur.knn), mur_coords, add=TRUE,col='red',lwd='2')
title(main=paste("Distance based neighbours (",neighbours,")"))
[2]___________
##points=vector
##output=output vector
library("spdep")
output <- listw2lines(nb2listw(knn2nb(knn)), coords)
The log error
Algorithm vecinos shape starting...
R execution commands
options("repos"="http://cran.us.r-project.org")
tryCatch(find.package("rgdal"), error=function(e) install.packages("rgdal",
lib="/Users/adiez/.qgis//sextante/rlibs"))
library("rgdal")
points = readOGR("/Users/adiez/Dropbox/tests",layer="turton_rand")
neighbours=3
library("spdep")
coords
knn
lines
writeLinesShape(lines,
paste('/Users/adiez/Dropbox/mursilandia/mapas_finales/k_neig_51',neighbours))
output=lines
writeOGR(output,"/var/folders/sm/1djysrdj1clbzvn35gv8vqq40000gn/T/sextante/rvecinosshapeb87dccb5ed70455683e8ad4e4a5139b5.shp","rvecinosshapeb87dccb5ed70455683e8ad4e4a5139b5",
driver="ESRI Shapefile")
R execution console output
R version 2.15.1 (2012-06-22) -- "Roasted Marshmallows"
Copyright (C) 2012 The R Foundation for Statistical Computing
ISBN 3-900051-07-0
Platform: i386-apple-darwin9.8.0/i386 (32-bit)
R is free software and comes with ABSOLUTELY NO WARRANTY.
You are welcome to redistribute it under certain conditions.
Type 'license()' or 'licence()' for distribution details.
Natural language support but running in an English locale
R is a collaborative project with many contributors.
Type 'contributors()' for more information and
'citation()' on how to cite R or R packages in publications.
Type 'demo()' for some demos, 'help()' for on-line help, or
'help.start()' for an HTML browser interface to help.
Type 'q()' to quit R.
[1] "/Users/adiez/Library/R/2.15/library/rgdal"
library("rgdal")
Loading required package: sp
Geospatial Data Abstraction Library extensions to R successfully loaded
Loaded GDAL runtime: GDAL 1.9.0, released 2011/12/29
Path to GDAL shared files: /Users/adiez/Library/R/2.15/library/rgdal/gdal
Loaded PROJ.4 runtime: Rel. 4.8.0, 6 March 2012, [PJ_VERSION: 480]
Path to PROJ.4 shared files: /Users/adiez/Library/R/2.15/library/rgdal/proj
OGR data source with driver: ESRI Shapefile
Source: "/Users/adiez/Dropbox/tests", layer: "turton_rand"
with 24 features and 2 fields
Feature type: wkbPoint with 2 dimensions
neighbours=3
library("spdep")
Loading required package: boot
Loading required package: Matrix
Loading required package: lattice
Attaching package: 'lattice'
The following object(s) are masked from 'package:boot':
melanoma
Loading required package: MASS
Loading required package: nlme
Loading required package: maptools
Loading required package: foreign
Checking rgeos availability: TRUE
Loading required package: deldir
deldir 0.0-19
PLEASE NOTE: The components "delsgs" and "summary" of the
object returned by deldir() are now DATA FRAMES rather than
matrices (as they were prior to release 0.0-18).
See help("deldir").
PLEASE NOTE: The process for determining duplicated points
has changed from that used in version 0.0-9 (and previously).
Loading required package: coda
coords
knn
lines
output=lines
Error in writeOGR(output,
Can't convert columns of class: AsIs; column names: i_ID,j_ID
Execution halted
Algorithm vecinos shape finished
[3]----------------------------------------
##points=vector
library("spdep")
lines <- listw2lines(nb2listw(knn2nb(knn)), coords)
output=lines
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130109/6521c950/attachment.html>
