[Qgis-user] SLD scale threshold
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Wed Jan 9 07:58:52 PST 2013
Hi List,
I have a QML file that has a scale threshold:
<qgis version="1.8.0-Lisboa" minimumScale="0" maximumScale="5000"
hasScaleBasedVisibilityFlag="1">
But when I export to SLD there is no threshold in the resultant file. I
believe it should be something like:
<MaxScaleDenominator>5000</MaxScaleDenominator>
Is this is a known limitation of QGIS?
Cheers,
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us,  including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130109/6ae46855/attachment.html>
