[Qgis-user] lost 'fetch python plugins' and vector menu
Albin Blaschka
albin.blaschka at standortsanalyse.net
Thu Jul 4 23:46:01 PDT 2013
Am 04.07.2013 18:45, schrieb Robert Nuske:
>> tried this link,
>> http://qgismalaysia.blogspot.com/2013/04/ubuntu-1304-and-qgis.html
> It describes how to install qgis-master, if I understood it correctly.
> But I am looking for the last stable release (QGIS 1.8).
Hello!
on 2 July I reported a similar experience in the already other mentioned
thread ("Fetch plugins missing"):
> At first I added the ubuntu-gis-repository (ppa), but that gave me
> a old version of QGIS, so I added the repository given at the
> download-page (http://qgis.org/debian raring main) and did an update,
> with which I got QGIS 1.8 as wished, but with missing "fetch plugins".
> I had to remove the ubuntugis ppa and doing a
> "sudo aptitude update && sudo aptitude safe-upgrade" brought it back...
HTH!
Albin
>> 2013/7/4 Robert Nuske <rnuske at gwdg.de>
>>> Hi Etienne,
>>> yes you are right, I obviously looked not carefully enough...
>>> Anyhow, the given solution is not working for me.
>>> python-pyspatialite is not installed, at least not after purging
>>> all qgis packages.
>>> I now also removed libspatialite5 and libspatialite3, which tore down the
>>> entire grass and gdal
>>> Then started again with installing qgis (ends up pulling again
>>> libspatialite3
>>> and libspatialite5 ), but nothing changed. Still no 'fetch python
>>> plugins'
>>> and no vector menu
>>> Is there another repository I should use besides or instead
>>> ubuntugis-unstable?
>>> cheers,
>>> robert
>>> Am Donnerstag, 4. Juli 2013, 12:07:02 schrieb Etienne Tourigny:
>>>> another user reported in a separate thread of this same list a few days
>>> ago
>>>> (subject is "Fetch plugins missing")
>>>> "I had to remove python-pyspatialite to get a correct installation of
>>>> python-qgis and get the python plugins working"
>>>> It's always a good idea to look for existing solutions in the mailing
>>> list
>>>> before posting...
>>>> cheers
>>>> Etienne
>>>> On Thu, Jul 4, 2013 at 12:02 PM, Robert Nuske <rnuske at gwdg.de> wrote:
>>>>> Dear partners in misery and merciful helpers,
>>>>> I've got the feeling the 1.8.0-2~raring1 QGIS package from
>>>>> ubuntugis-unstable for 13.04 64bit is broken.
>>>>> Yes, I did
>>>>> - purge every qgis package separately
>>>>> - delete all the .qgis folders
>>>>> - now also reboot and aptitude update & aptitude dist-upgrade
>>>>> (no idea what for)
>>>>> - a fresh install of the qgis package
>>>>> The old 1.8.0-1~quantal3 32bit QGIS package on another computer works
>>>>> like a charm. I hope I do not have to build from source to get a
>>> working
>>>>> QGIS 1.8 on a recent Ubuntu.
>>>>> Is the package really broken or did I do something utterly wrong?
>>>>> cheers,
>>>>> robert
>>>>> Am Donnerstag, 4. Juli 2013, 14:53:44 schrieb Saber Razmjooei:
>>>>>> If you run qgis from terminal, what error message(s) do you get?
>>>>>> From: Joshua Hattingh [mailto:josh at rockstock.co.za]
>>>>>> Sent: 04 July 2013 14:52
>>>>>> To: Saber Razmjooei
>>>>>> Cc: Nathan Woodrow; qgis-user at lists.osgeo.org; Robert Nuske
>>>>>> Subject: Re: [Qgis-user] lost 'fetch python plugins' and vector menu
>>>>>> Tried that, still no luck - no fetch python plugins and no
>>>>>> openlayers
>>>>>> plugin.
>>>>>> J
>>>>>> On 4 July 2013 15:42, Saber Razmjooei
>>>>>> <saber.razmjooei at lutraconsulting.co.uk> wrote:
>>>>>> If you are using 1.8, I guess there is no API change for it, so the
>>>>>> following should do:
>>>>>> sudo apt-get purge python-qgis
>>>>>> sudo apt-get update
>>>>>> sudo apt-get dist-upgrade
>>>>>> sudo apt-get install python-qgis
>>>>>> Just to be 100% sure!
>>>>>> Cheers
>>>>>> Saber
>>>>>> www.lutraconsulting.co.uk <http://www.lutraconsulting.co.uk/>
>>>>>> From: qgis-user-bounces at lists.osgeo.org
>>>>>> [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Joshua
>>> Hattingh
>>>>>> Sent: 04 July 2013 14:38
>>>>>> To: Nathan Woodrow
>>>>>> Cc: qgis-user at lists.osgeo.org; Robert Nuske
>>>>>> Can we fix our installations? If so, how? In point form. Do A then B
>>>>> then C
>>>>>> etc.
>>>>>> Thanks,
>>>>>> J
>>>>>> On 4 July 2013 15:34, Nathan Woodrow <madmanwoo at gmail.com> wrote:
>>>>>> The plugin install has been merged into the plugin manager.
>>>>>> The API has also chmaged so all plugins need to be updated. This is
>>> why
>>>>> you
>>>>>> are missing some of the plugins you used to have.
>>>>>> Sent from some fancy phone looking thingo
>>>>>> _____
>>>>>> Sent: 4/07/2013 11:29 PM
>>>>>> To: Robert Nuske
>>>>>> Hi Robert
>>>>>> I have the same problem (I'm trying to get Openlayers plugin but
>>>>>> also
>>>>> don't
>>>>>> have the "Fetch Python Plugins" menu option, and can't get help
>>>>>> anywhere,
>>>>>> been through the same methods as you. I'm on Raring and 1.8 or 1.9
>>> and
>>>>> same
>>>>>> problem on both. I've tried for 2 weeks to fix but cannot. Let me
>>> know
>>>>>> if
>>>>>> you find the secret. There's a fix but it doesn't work for me.
>>>>>> Regards,
>>>>>> Josh
>>>>>> On 4 July 2013 14:38, Robert Nuske <rnuske at gwdg.de> wrote:
>>>>>> Dear QGISers,
>>>>>> somehow I have no vector menu and can not find the menu entry
>>>>>> 'fetch python plugins'.
>>>>>> Being on Kubuntu 13.04 64bit I have my QGIS (1.8.0-2~raring1) from
>>>>>> ubuntugis-unstable.
>>>>>> I deleted any .qgis folders, purged any qgis package and did a fresh
>>>>> install
>>>>>> of qgis (aptitude install qgis). I have no clue what else I
>>> could/should
>>>>>> try.
>>>>>> Any help is more than appreciated
>>>>>> cheers,
>>>>>> robert
>>>>>> Additional Information:
>>>>>> $ sudo apt-cache policy qgis
>>>>>> qgis:
>>>>>> Installiert: 1.8.0-2~raring1
>>>>>> Installationskandidat: 1.8.0-2~raring1
>>>>>> Versionstabelle:
>>>>>> *** 1.8.0-2~raring1 0
>>>>>> 500 http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu/
>>>>>> raring/main amd64 Packages
>>>>>> 100 /var/lib/dpkg/status
>>>>>> 1.7.4+1.7.5~20120320-1.1 0
>>>>>> 500 http://de.archive.ubuntu.com/ubuntu/ raring/universe amd64
>>> Packages
>>>>>> $ sudo aptitude search qgis
>>>>>> p libqgis-dev - Quantum GIS - development files
>>>>>> p libqgis-dev:i386 - Quantum GIS - development files
>>>>>> p libqgis1.7.5 - Quantum GIS - shared libraries
>>>>>> p libqgis1.7.5:i386 - Quantum GIS - shared libraries
>>>>>> i A libqgis1.8.0 - Quantum GIS - shared libraries
>>>>>> p libqgis1.8.0:i386 - Quantum GIS - shared libraries
>>>>>> i A python-qgis - Python bindings to Quantum GIS
>>>>>> p python-qgis:i386 - Python bindings to Quantum GIS
>>>>>> i A python-qgis-common - Python bindings to Quantum GIS - ar
>>>>>> v python2.7-qgis -
>>>>>> v python2.7-qgis:i386 -
>>>>>> i qgis - Geografisches Informationssystem (G
>>>>>> p qgis:i386 - Geografisches Informationssystem (G
>>>>>> p qgis-api-doc - Quantum GIS API documentation
>>>>>> i A qgis-common - Quantum GIS - architecture-independ
>>>>>> v qgis-dev -
>>>>>> v qgis-dev:i386 -
>>>>>> p qgis-mapserver - Quantum GIS mapserver
>>>>>> p qgis-mapserver:i386 - Quantum GIS mapserver
>>>>>> i A qgis-plugin-globe - OSG globe plugin for Quantum GIS
>>>>>> p qgis-plugin-globe:i386 - OSG globe plugin for Quantum GIS
>>>>>> i A qgis-plugin-globe-common - OSG GLOBE plugin for Quantum GIS -
>>>>>> i A qgis-plugin-grass - GRASS plugin for Quantum GIS
>>>>>> p qgis-plugin-grass:i386 - GRASS plugin for Quantum GIS
>>>>>> i A qgis-plugin-grass-common - GRASS plugin for Quantum GIS - arch
>>>>>> i A qgis-providers - collection of data providers to Qua
>>>>>> p qgis-providers:i386 - collection of data providers to Qua
>>>>>> i A qgis-providers-common - collection of data providers to Qua
>>>>>> p qgis-sqlanywhere - Quantum GIS sql anywhere plugin and
>>>>>> p qgis-sqlanywhere:i386 - Quantum GIS sql anywhere plugin and
>>>>>> p qgis-sqlanywhere1.7.5 - Quantum GIS sql anywhere plugin and
>>>>>> p qgis-sqlanywhere1.7.5:i386 - Quantum GIS sql anywhere plugin and
>>>>>> _______________________________________________
>>>>>> Qgis-user mailing list
>>>>>> Qgis-user at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>> _____
>>>>>> This email and any files transmitted with it are confidential and
>>>>> intended
>>>>>> solely for the use of the individual or entity to whom they are
>>>>> addressed.
>>>>>> If you have received this email in error please notify the system
>>>>> manager.
>>>>>> This message contains confidential information and is intended only
>>> for
>>>>> the
>>>>>> individual named. If you are not the named addressee you should not
>>>>>> disseminate, distribute or copy this e-mail. Please notify the
>>>>>> sender
>>>>>> immediately by e-mail if you have received this e-mail by mistake
>>>>>> and
>>>>> delete
>>>>>> this e-mail from your system. If you are not the intended recipient
>>> you
>>>>> are
>>>>>> notified that disclosing, copying, distributing or taking any action
>>> in
>>>>>> reliance on the contents of this information is strictly prohibited.
>>>>>> Whilst reasonable care has been taken to avoid virus transmission,
>>>>>> no
>>>>>> responsibility for viruses is taken and it is your responsibility to
>>>>> carry
>>>>>> out such checks as you feel appropriate.
>>>>>> Saber Razmjooei and Peter Wells trading as Lutra Consulting.
| Albin Blaschka, Mag.rer.nat.
| Etrichstrasse 26, A-5020 Salzburg
| * www.albinblaschka.info *
| * www.researchgate.net/profile/Albin_Blaschka *
| - It's hard to live in the mountains, hard but not hopeless!
