[Qgis-user] QGIS installation problem with Mac OSX 10.8.4 and some Qt4 Modules
William Kyngesburye woklist at kyngchaos.com
Fri Jul 5 10:22:38 PDT 2013
On Jul 5, 2013, at 12:01 PM, Marcel Stadelmann wrote:
> Thank you for answering. In the meantime i got a step forward. I can successfully cmake qgis (see below), but when i do "make -j 8" it gives quite a lot of errors. The errors look i. e. like this:
> [ 56%] Generating moc_qgsabout.cxx
> In file included from /Users/Marcello/Downloads/Quantum-GIS-master/src/providers/spatialite/qgsspatialiteprovider.cpp:29:
> /Users/Marcello/Downloads/Quantum-GIS-master/src/providers/spatialite/qgsspatialiteprovider.h:393:43: error: unknown type name 'gaiaVectorLayerPtr'; did you mean 'gaiaTextReaderPtr'?
>    bool checkLayerTypeAbstractInterface( gaiaVectorLayerPtr lyr );
>                                          gaiaTextReaderPtr
If they're all about spatialite, then this could be an old or incomplete spatialite install (/usr/local) or confusion with the SQLite framework vs. your /usr/local install.
>> Did you have any problems compiling SIP/PyQt after installing Qt 4.8.5?  If updating to a newer Qt, did you recompile SIP/PyQt?
> Yes, PyQt did not work with sip 4.14.7 so I installed sip 4.14.6 with homebrew. After reinstalling Qt 4.8.4, sip 4.14.6, PyQt4 4.10.1, QScintilla2 2.7.2 (all with homebrew) and Qwt 6.0.2 (conventional) i can do at least the cmake.
There should be no problems with SIP 4.14.7, PyQt 4.10.2 and Qt 4.8.5 (just tried it myself).
> Marcels-iMac:build Marcello$ cmake -D CMAKE_INSTALL_PREFIX=~/Applications \
>>  -D CMAKE_BUILD_TYPE=MINSIZEREL -D ENABLE_TESTS=FALSE \
>>  -D WITH_INTERNAL_SPATIALITE=FALSE -D WITH_PYSPATIALITE=FALSE \
>>  -D SPATIALINDEX_LIBRARY=/usr/local/lib/libspatialindex.dylib \
>>  -D SPATIALINDEX_INCLUDE_DIR=/usr/local/include/spatialindex \
>>  -D QWT_LIBRARY=/usr/local/qwt-6.0.2/lib/libqwt.dylib \
>>  -D QWT_INCLUDE_DIR=/usr/local/qwt-6.0.2/include \
>>  -D BISON_EXECUTABLE=/usr/local/bin/bison \
>>  -D CMAKE_FIND_FRAMEWORK=LAST \
>>  -D QGIS_MACAPP_BUNDLE=2 \
> -- QGIS version: 1.9.0 Master (10900)
> -- Found GRASS: /Applications/GRASS-6.4.app/Contents/MacOS (6.4.2)
> -- Found Proj: /Library/Frameworks/PROJ.framework
> -- Found GEOS: /Library/Frameworks/GEOS.framework
> -- Found GDAL: /usr/local/Cellar/gdal/1.9.2/lib/libgdal.dylib (1.9.2)
> -- Found Expat: /usr/local/lib/libexpat.dylib
> -- Found Spatialindex: /usr/local/lib/libspatialindex.dylib
> -- Found Qwt: /usr/local/qwt-6.0.2/lib/libqwt.dylib (6.0.2)
> -- Found Sqlite3: /Library/Frameworks/sqlite3.framework
> -- Found PostgreSQL: /usr/local/pgsql-9.1/lib/libpq.dylib
> -- Found SpatiaLite: /usr/local/lib/libspatialite.dylib
> -- Touch support disabled
> -- Found QScintilla2: /usr/local/lib/libqscintilla2.dylib (2.7.2)
> -- Pedantic compiler settings enabled
> -- Found Python executable: /System/Library/Frameworks/Python.framework/Versions/2.7/bin/python2.7
> -- Found Python version: 2.7.2
> -- Found Python library: -framework Python
> -- Found SIP version: 4.14.6
> -- Found PyQt4 version: 4.10.1
> -- Found QScintilla2 PyQt4 module: qsci_version_str:
> -- Found GSL: -L/usr/local/Cellar/gsl/1.15/lib -lgsl -lgslcblas
> -- Found FCGI: /usr/local/lib/libfcgi.dylib
> -- txt2tags not found - disabled
> -- Configuring done
> -- Generating done
> -- Build files have been written to: /Users/Marcello/Downloads/Quantum-GIS-master/build
>> Are you following the compiling instructions in the INSTALL doc?
> Since not everything work well, i started to install the required components with homebrew. But i tried to respect the order of installing.
Sorry, I don't do homebrew (or any other package manager), so I can't help if it has messed up something or is confusing configuration.
I actually haven't checked the install instructions in a while (something I need to do before release), but my own notes haven't changed in a while so INSTALL should still be good.
>> P.S.  note about spatialite on OS X - if you use my SQLite framework, it includes spatialite, so there is no need to install your own.  QGIS might get confused and crash if it finds another spatialite (ie in SQLite framework) than it was compiled with (ie /usr/local)
> How can I remove it?
It?  as in /usr/local spatialite?  I'm not sure exactly what files are installed, but look for:
/usr/local/bin:
  exif_locader
  rasterlite*
  shp_doctor
  spatialite*
/usr/local/lib:
  librasterlite*.dylib
  libspatialite*.dylib
/usr/local/include:
  spatialite [a folder]
  spatialite.h
For QGIS cmake configuration, just remove the spatialite library & include options and it will automatically find my SQLite (spatialite) framework.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"We are at war with them. Neither in hatred nor revenge and with no particular pleasure I shall kill every ___ I can until the war is over. That is my duty."
"Don't you even hate 'em?"
"What good would it do if I did? If all the many millions of people of the allied nations devoted an entire year exclusively to hating the ____ it wouldn't kill one ___ nor shorten the war one day."
<Ha, ha> "And it might give 'em all stomach ulcers."
- Tarzan, on war
