[Qgis-user] QGIS installation problem with Mac OSX 10.8.4 and some Qt4 Modules
Marcel Stadelmann
marcel.stadelmann at gmx.net
Sat Jul 6 01:16:12 PDT 2013
Hello,
I removed everything from homebrew which could cause problems for a QGIS installation. I just left bison and expat in homebrew, for sqlite I was not sure if I can leave it (see below the brew list). Then I installed the required components according the install instruction, Qt 4.8.5, your frameworks (gdal complete) and postgres+postgis extension, spatialindex 1.8.1and sip 4.14.7. I got stacked installing PyQt 4.10.2. This program looks for sip 4.14.6 which is the old (previous) installation (see below). My interpretation is that the sip 4.14.7 installation was not good, although there was no error message. Any idea?
Thank you
Marcel
Marcels-iMac:PyQt-mac-gpl-4.10.2 Marcello$ python2.7 configure.py -d /Library/Python/2.7/site-packages -b /usr/local/bin -n /usr/local/Qt4.8/qsci -v /usr/local/share/sip/PyQt4
Determining the layout of your Qt installation...
This is the GPL version of PyQt 4.10.2 (licensed under the GNU General Public
License) for Python 2.7.2 on darwin.
Type '2' to view the GPL v2 license.
Type '3' to view the GPL v3 license.
Type 'yes' to accept the terms of the license.
Type 'no' to decline the terms of the license.
Do you accept the terms of the license? yes
Found the license file pyqt-gpl.sip.
Checking to see if the QtGui module should be built...
Checking to see if the QtHelp module should be built...
Checking to see if the QtMultimedia module should be built...
Checking to see if the QtNetwork module should be built...
Checking to see if the QtDBus module should be built...
Checking to see if the QtDeclarative module should be built...
Checking to see if the QtOpenGL module should be built...
Checking to see if the QtScript module should be built...
Checking to see if the QtScriptTools module should be built...
Checking to see if the QtSql module should be built...
Checking to see if the QtSvg module should be built...
Checking to see if the QtTest module should be built...
Checking to see if the QtWebKit module should be built...
Checking to see if the QtXml module should be built...
Checking to see if the QtXmlPatterns module should be built...
Checking to see if the phonon module should be built...
Checking to see if the QtAssistant module should be built...
Checking to see if the QtDesigner module should be built...
Checking to see if the QAxContainer module should be built...
Checking to see if the dbus support module should be built...
DBus v1 does not seem to be installed.
Qt v4.8.5 free edition is being used.
Qt is built as a framework.
SIP 4.14.6 is being used.
The Qt header files are in /usr/include.
The shared Qt libraries are in /Library/Frameworks.
The Qt binaries are in /Developer/Tools/Qt.
The Qt mkspecs directory is in /usr/local/Qt4.8.
These PyQt modules will be built: QtCore, QtGui, QtHelp, QtMultimedia,
QtNetwork, QtDBus, QtDeclarative, QtOpenGL, QtScript, QtScriptTools, QtSql,
QtSvg, QtTest, QtWebKit, QtXml, QtXmlPatterns, phonon, QtDesigner.
The PyQt Python package will be installed in /Library/Python/2.7/site-packages.
PyQt is being built with generated docstrings.
PyQt is being built with 'protected' redefined as 'public'.
The Designer plugin will be installed in
/Developer/Applications/Qt/plugins/designer.
The QScintilla API file will be installed in /usr/local/Qt4.8/qsci/api/python.
The PyQt .sip files will be installed in /usr/local/share/sip/PyQt4.
pyuic4, pyrcc4 and pylupdate4 will be installed in /usr/local/bin.
Embedding sip flags...
Generating the C++ source for the QtCore module...
sh: /usr/local/Cellar/sip/4.14.6/bin/sip: No such file or directory
Error: Unable to create the C++ code.
Marcels-iMac:PyQt-mac-gpl-4.10.2 Marcello$ sip -V
4.14.7
Marcels-iMac:PyQt-mac-gpl-4.10.2 Marcello$ which sip
/usr/local/bin/sip
Marcels-iMac:PyQt-mac-gpl-4.10.2 Marcello$ brew list
atk cairo expat gdbm ghostscript gsl imagemagick latex2rtf libpng little-cms2 pixman sqlite
autoconf check fontconfig gdk-pixbuf giflib gtk+ intltool libcroco librsvg lzlib pkg-config xz
automake cmake freetype geos glib harfbuzz jbig2dec libffi libtiff ossp-uuid proj
bison doxygen freexl gettext graphicsmagick icu4c jpeg libgeotiff libtool pango readline
Am 05.07.2013 um 19:22 schrieb William Kyngesburye <woklist at kyngchaos.com>:
> On Jul 5, 2013, at 12:01 PM, Marcel Stadelmann wrote:
>> Thank you for answering. In the meantime i got a step forward. I can successfully cmake qgis (see below), but when i do "make -j 8" it gives quite a lot of errors. The errors look i. e. like this:
>> [ 56%] Generating moc_qgsabout.cxx
>> In file included from /Users/Marcello/Downloads/Quantum-GIS-master/src/providers/spatialite/qgsspatialiteprovider.cpp:29:
>> /Users/Marcello/Downloads/Quantum-GIS-master/src/providers/spatialite/qgsspatialiteprovider.h:393:43: error: unknown type name 'gaiaVectorLayerPtr'; did you mean 'gaiaTextReaderPtr'?
>> bool checkLayerTypeAbstractInterface( gaiaVectorLayerPtr lyr );
>> gaiaTextReaderPtr
> If they're all about spatialite, then this could be an old or incomplete spatialite install (/usr/local) or confusion with the SQLite framework vs. your /usr/local install.
>>> Did you have any problems compiling SIP/PyQt after installing Qt 4.8.5? If updating to a newer Qt, did you recompile SIP/PyQt?
>> Yes, PyQt did not work with sip 4.14.7 so I installed sip 4.14.6 with homebrew. After reinstalling Qt 4.8.4, sip 4.14.6, PyQt4 4.10.1, QScintilla2 2.7.2 (all with homebrew) and Qwt 6.0.2 (conventional) i can do at least the cmake.
> There should be no problems with SIP 4.14.7, PyQt 4.10.2 and Qt 4.8.5 (just tried it myself).
>> Marcels-iMac:build Marcello$ cmake -D CMAKE_INSTALL_PREFIX=~/Applications \
>>> -D CMAKE_BUILD_TYPE=MINSIZEREL -D ENABLE_TESTS=FALSE \
>>> -D WITH_INTERNAL_SPATIALITE=FALSE -D WITH_PYSPATIALITE=FALSE \
>>> -D SPATIALINDEX_LIBRARY=/usr/local/lib/libspatialindex.dylib \
>>> -D SPATIALINDEX_INCLUDE_DIR=/usr/local/include/spatialindex \
>>> -D QWT_LIBRARY=/usr/local/qwt-6.0.2/lib/libqwt.dylib \
>>> -D QWT_INCLUDE_DIR=/usr/local/qwt-6.0.2/include \
>>> -D BISON_EXECUTABLE=/usr/local/bin/bison \
>>> -D CMAKE_FIND_FRAMEWORK=LAST \
>>> -D QGIS_MACAPP_BUNDLE=2 \
>> -- QGIS version: 1.9.0 Master (10900)
>> -- Found GRASS: /Applications/GRASS-6.4.app/Contents/MacOS (6.4.2)
>> -- Found Proj: /Library/Frameworks/PROJ.framework
>> -- Found GEOS: /Library/Frameworks/GEOS.framework
>> -- Found GDAL: /usr/local/Cellar/gdal/1.9.2/lib/libgdal.dylib (1.9.2)
>> -- Found Expat: /usr/local/lib/libexpat.dylib
>> -- Found Spatialindex: /usr/local/lib/libspatialindex.dylib
>> -- Found Qwt: /usr/local/qwt-6.0.2/lib/libqwt.dylib (6.0.2)
>> -- Found Sqlite3: /Library/Frameworks/sqlite3.framework
>> -- Found PostgreSQL: /usr/local/pgsql-9.1/lib/libpq.dylib
>> -- Found SpatiaLite: /usr/local/lib/libspatialite.dylib
>> -- Touch support disabled
>> -- Found QScintilla2: /usr/local/lib/libqscintilla2.dylib (2.7.2)
>> -- Pedantic compiler settings enabled
>> -- Found Python executable: /System/Library/Frameworks/Python.framework/Versions/2.7/bin/python2.7
>> -- Found Python version: 2.7.2
>> -- Found Python library: -framework Python
>> -- Found SIP version: 4.14.6
>> -- Found PyQt4 version: 4.10.1
>> -- Found QScintilla2 PyQt4 module: qsci_version_str:
>> -- Found GSL: -L/usr/local/Cellar/gsl/1.15/lib -lgsl -lgslcblas
>> -- Found FCGI: /usr/local/lib/libfcgi.dylib
>> -- txt2tags not found - disabled
>> -- Configuring done
>> -- Generating done
>> -- Build files have been written to: /Users/Marcello/Downloads/Quantum-GIS-master/build
>>> Are you following the compiling instructions in the INSTALL doc?
>> Since not everything work well, i started to install the required components with homebrew. But i tried to respect the order of installing.
> Sorry, I don't do homebrew (or any other package manager), so I can't help if it has messed up something or is confusing configuration.
> I actually haven't checked the install instructions in a while (something I need to do before release), but my own notes haven't changed in a while so INSTALL should still be good.
>>> P.S. note about spatialite on OS X - if you use my SQLite framework, it includes spatialite, so there is no need to install your own. QGIS might get confused and crash if it finds another spatialite (ie in SQLite framework) than it was compiled with (ie /usr/local)
>> How can I remove it?
> It? as in /usr/local spatialite? I'm not sure exactly what files are installed, but look for:
> /usr/local/bin:
> exif_locader
> rasterlite*
> shp_doctor
> spatialite*
> /usr/local/lib:
> librasterlite*.dylib
> libspatialite*.dylib
> /usr/local/include:
> spatialite [a folder]
> spatialite.h
> For QGIS cmake configuration, just remove the spatialite library & include options and it will automatically find my SQLite (spatialite) framework.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "We are at war with them. Neither in hatred nor revenge and with no particular pleasure I shall kill every ___ I can until the war is over. That is my duty."
> "Don't you even hate 'em?"
> "What good would it do if I did? If all the many millions of people of the allied nations devoted an entire year exclusively to hating the ____ it wouldn't kill one ___ nor shorten the war one day."
> <Ha, ha> "And it might give 'em all stomach ulcers."
> - Tarzan, on war
