[Qgis-user] QGIS installation problem with Mac OSX 10.8.4 and some Qt4 Modules
William Kyngesburye woklist at kyngchaos.com
Sun Jul 7 10:36:02 PDT 2013
Hooray for the obvious!  I thought I'd go crazy on this one.
Don't know about the non-starting python.  Were there any details with the error?  Maybe there is something in Console.app?
On Jul 7, 2013, at 12:19 PM, Marcel Stadelmann wrote:
> Yes, deleting the content of build helped, now it looks good (see below) and in the meantime I could install successfully QGIS. But when I start QGIS the following error appears: PyQGIS konnte nicht geladen werden. Die Python-Unterstützung wird abgeschaltet. Means: PyQGIS could not be loaded. Python support is switched off.
> I installed cmake from scratch, but it is also installed in homebrew. The /usr/local/Cellar path is the homebrew path. I will now remove this components from homebrew.
> Marcels-iMac:build Marcello$ cmake -D CMAKE_INSTALL_PREFIX=~/Applications   -D CMAKE_BUILD_TYPE=MINSIZEREL -D ENABLE_TESTS=FALSE   -D WITH_INTERNAL_SPATIALITE=FALSE -D WITH_PYSPATIALITE=FALSE   -D SPATIALINDEX_LIBRARY=/usr/local/lib/libspatialindex.dylib   -D SPATIALINDEX_INCLUDE_DIR=/usr/local/include/spatialindex   -D QWT_LIBRARY=/usr/local/qwt-6.0.2/lib/libqwt.dylib   -D QWT_INCLUDE_DIR=/usr/local/qwt-6.0.2/include   -D BISON_EXECUTABLE=/usr/local/bin/bison ..
> -- The C compiler identification is Clang 4.2.0
> -- The CXX compiler identification is Clang 4.2.0
> -- Check for working C compiler: /usr/bin/cc
> -- Check for working C compiler: /usr/bin/cc -- works
> -- Detecting C compiler ABI info
> -- Detecting C compiler ABI info - done
> -- Check for working CXX compiler: /usr/bin/c++
> -- Check for working CXX compiler: /usr/bin/c++ -- works
> -- Detecting CXX compiler ABI info
> -- Detecting CXX compiler ABI info - done
> -- QGIS version: 1.9.0 Master (10900)
> -- Found GRASS: /Applications/GRASS-6.4.app/Contents/MacOS (6.4.2)
> -- Looking for openpty
> -- Looking for openpty - found
> -- Found Proj: /Library/Frameworks/PROJ.framework
> -- Found GEOS: /Library/Frameworks/GEOS.framework
> -- Found GDAL: /Library/Frameworks/GDAL.framework (1.10.0)
> -- Found Expat: /usr/local/lib/libexpat.dylib
> -- Found Spatialindex: /usr/local/lib/libspatialindex.dylib
> -- Found Qwt: /usr/local/qwt-6.0.2/lib/libqwt.dylib (6.0.2)
> -- Found Sqlite3: /Library/Frameworks/SQLite3.framework
> -- Found PostgreSQL: /usr/local/pgsql-9.2/lib/libpq.dylib
> -- Found SpatiaLite: /Library/Frameworks/SQLite3.framework
> -- Looking for gaiaDropTable in /Library/Frameworks/SQLite3.framework
> -- Looking for gaiaDropTable in /Library/Frameworks/SQLite3.framework - found
> -- Looking for Q_WS_X11
> -- Looking for Q_WS_X11 - not found
> -- Looking for Q_WS_WIN
> -- Looking for Q_WS_WIN - not found
> -- Looking for Q_WS_QWS
> -- Looking for Q_WS_QWS - not found
> -- Looking for Q_WS_MAC
> -- Looking for Q_WS_MAC - found
> -- Looking for QT_MAC_USE_COCOA
> -- Looking for QT_MAC_USE_COCOA - found
> -- Found Qt4: /usr/bin/qmake (found suitable version "4.8.5", minimum required is "4.4.0")
> -- Touch support disabled
> -- Found QScintilla2: /usr/local/lib/libqscintilla2.dylib (2.7.2)
> -- Pedantic compiler settings enabled
> -- Found PythonInterp: /usr/bin/python (found version "2.7.2")
> -- Found Python executable: /usr/bin/python
> -- Found Python version: 2.7.2
> -- Found Python library: -framework Python
> -- Found SIP version: 4.14.6
> -- Found PyQt4 version: 4.10.2
> -- Found QScintilla2 PyQt4 module: 2.7.2
> fatal: Not a git repository (or any of the parent directories): .git
> -- Found GSL: /Library/Frameworks/GSL.framework
> -- txt2tags not found - disabled
> -- Configuring done
> -- Generating done
> -- Build files have been written to: /Users/Marcello/Downloads/Quantum-GIS-master/build
> Am 07.07.2013 um 18:59 schrieb William Kyngesburye <woklist at kyngchaos.com>:
>> Ah, cmake installed by homebrew.  I looked at the homebrew setup for cmake, no patches that would change behavior, but I do see a different configuration setting that I don't know how it will affect cmake: --system-libs.  The default (if you install from scratch like in the QGIS install doc) is --no-system-libs.
>> Uninstalling homebrew GEOS and sqlite may help, but there are other things as well: PROJ in homebrew, and GEOS in /usr/local/Cellar (whatever that is).  And it's not even finding the homebrew sqlite, it's finding the system sqlite.
>> On Jul 7, 2013, at 11:48 AM, William Kyngesburye wrote:
>>> No unusual PATH stuff.
>>> PYTHONPATH may cause problems running any GDAL programs that are python scripts.  Though it gets added before .pth stuff, so it's probably OK.
>>> PROJSO is meaningless for my GDAL framework - it's only used when dynamically loading the PROJ library, my framework has it statically linked (completely different from shared vs. static library).
>>> So, nothing that looks like it would change cmake behavior...
>> Are you compiling cmake from scratch, or from homebrew?On Jul 7, 2013, at 11:48 AM, Marcel Stadelmann wrote:
>>> Maybe the problem lies in the GEOS or in sqlite. This two things are still in homebrew installed. Can i remove them?
>>> Marcels-iMac:~ Marcello$ brew list
>>> atk		cmake		gdbm		glib		imagemagick	libffi		little-cms2	proj
>>> autoconf	doxygen		gdk-pixbuf	graphicsmagick	intltool	libgeotiff	lzlib		readline
>>> automake	expat		geos		gsl		jbig2dec	libpng		ossp-uuid	sqlite
>>> bison		fontconfig	gettext		gtk+		jpeg		librsvg		pango		xz
>>> cairo		freetype	ghostscript	harfbuzz	latex2rtf	libtiff		pixman
>>> check		freexl		giflib		icu4c		libcroco	libtool		pkg-config
>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>> http://www.kyngchaos.com/
>> "I ache, therefore I am.  Or in my case - I am, therefore I ache."
>> - Marvin
> Qgis-user mailing list
The equator is so long, it could encircle the earth completely once.
