[Qgis-user] QGIS installation problem with Mac OSX 10.8.4 and some Qt4 Modules
Marcel Stadelmann
marcel.stadelmann at gmx.net
Sun Jul 7 12:12:49 PDT 2013
I removed PYTHONPATH in my .bash_profile and recompiled everything from SIP on. But still the same error occurs in QGIS.
Am 07.07.2013 um 19:50 schrieb William Kyngesburye <woklist at kyngchaos.com>:
> Looks like the SIP and/or PyQt that QGIS finds at runtime is different from the one found in compilation.
> This may be related to the PYTHONPATH in your .bash_profile - compilation sees this and may get the wrong SIP/PyQt, but OS X apps do see any environment settings in .bash_profile or any other shell init file. Try commenting this out and reconfiguring and compiling QGIS. You may need to go back to recompiling SIP and PyQt outside of homebrew.
> On Jul 7, 2013, at 12:45 PM, Marcel Stadelmann wrote:
>> Below the error message, there is the following additional text, but I don't know if it is with the PyQGIS related:
>> Traceback (most recent call last):
>> File "", line 1, in
>> RuntimeError: the sip module implements API v9.0 to v9.1 but the qgis.core module requires API v9.2
>> Am 07.07.2013 um 19:36 schrieb William Kyngesburye <woklist at kyngchaos.com>:
>>> Hooray for the obvious! I thought I'd go crazy on this one.
>>> Don't know about the non-starting python. Were there any details with the error? Maybe there is something in Console.app?
>>> On Jul 7, 2013, at 12:19 PM, Marcel Stadelmann wrote:
>>>> Yes, deleting the content of build helped, now it looks good (see below) and in the meantime I could install successfully QGIS. But when I start QGIS the following error appears: PyQGIS konnte nicht geladen werden. Die Python-Unterstützung wird abgeschaltet. Means: PyQGIS could not be loaded. Python support is switched off.
>>>> I installed cmake from scratch, but it is also installed in homebrew. The /usr/local/Cellar path is the homebrew path. I will now remove this components from homebrew.
>>>> Marcels-iMac:build Marcello$ cmake -D CMAKE_INSTALL_PREFIX=~/Applications -D CMAKE_BUILD_TYPE=MINSIZEREL -D ENABLE_TESTS=FALSE -D WITH_INTERNAL_SPATIALITE=FALSE -D WITH_PYSPATIALITE=FALSE -D SPATIALINDEX_LIBRARY=/usr/local/lib/libspatialindex.dylib -D SPATIALINDEX_INCLUDE_DIR=/usr/local/include/spatialindex -D QWT_LIBRARY=/usr/local/qwt-6.0.2/lib/libqwt.dylib -D QWT_INCLUDE_DIR=/usr/local/qwt-6.0.2/include -D BISON_EXECUTABLE=/usr/local/bin/bison ..
>>>> -- The C compiler identification is Clang 4.2.0
>>>> -- The CXX compiler identification is Clang 4.2.0
>>>> -- Check for working C compiler: /usr/bin/cc
>>>> -- Check for working C compiler: /usr/bin/cc -- works
>>>> -- Detecting C compiler ABI info
>>>> -- Detecting C compiler ABI info - done
>>>> -- Check for working CXX compiler: /usr/bin/c++
>>>> -- Check for working CXX compiler: /usr/bin/c++ -- works
>>>> -- Detecting CXX compiler ABI info
>>>> -- Detecting CXX compiler ABI info - done
>>>> -- QGIS version: 1.9.0 Master (10900)
>>>> -- Found GRASS: /Applications/GRASS-6.4.app/Contents/MacOS (6.4.2)
>>>> -- Looking for openpty
>>>> -- Looking for openpty - found
>>>> -- Found Proj: /Library/Frameworks/PROJ.framework
>>>> -- Found GEOS: /Library/Frameworks/GEOS.framework
>>>> -- Found GDAL: /Library/Frameworks/GDAL.framework (1.10.0)
>>>> -- Found Expat: /usr/local/lib/libexpat.dylib
>>>> -- Found Spatialindex: /usr/local/lib/libspatialindex.dylib
>>>> -- Found Qwt: /usr/local/qwt-6.0.2/lib/libqwt.dylib (6.0.2)
>>>> -- Found Sqlite3: /Library/Frameworks/SQLite3.framework
>>>> -- Found PostgreSQL: /usr/local/pgsql-9.2/lib/libpq.dylib
>>>> -- Found SpatiaLite: /Library/Frameworks/SQLite3.framework
>>>> -- Looking for gaiaDropTable in /Library/Frameworks/SQLite3.framework
>>>> -- Looking for gaiaDropTable in /Library/Frameworks/SQLite3.framework - found
>>>> -- Looking for Q_WS_X11
>>>> -- Looking for Q_WS_X11 - not found
>>>> -- Looking for Q_WS_WIN
>>>> -- Looking for Q_WS_WIN - not found
>>>> -- Looking for Q_WS_QWS
>>>> -- Looking for Q_WS_QWS - not found
>>>> -- Looking for Q_WS_MAC
>>>> -- Looking for Q_WS_MAC - found
>>>> -- Looking for QT_MAC_USE_COCOA
>>>> -- Looking for QT_MAC_USE_COCOA - found
>>>> -- Found Qt4: /usr/bin/qmake (found suitable version "4.8.5", minimum required is "4.4.0")
>>>> -- Touch support disabled
>>>> -- Found QScintilla2: /usr/local/lib/libqscintilla2.dylib (2.7.2)
>>>> -- Pedantic compiler settings enabled
>>>> -- Found PythonInterp: /usr/bin/python (found version "2.7.2")
>>>> -- Found Python executable: /usr/bin/python
>>>> -- Found Python version: 2.7.2
>>>> -- Found Python library: -framework Python
>>>> -- Found SIP version: 4.14.6
>>>> -- Found PyQt4 version: 4.10.2
>>>> -- Found QScintilla2 PyQt4 module: 2.7.2
>>>> fatal: Not a git repository (or any of the parent directories): .git
>>>> -- Found GSL: /Library/Frameworks/GSL.framework
>>>> -- txt2tags not found - disabled
>>>> -- Configuring done
>>>> -- Generating done
>>>> -- Build files have been written to: /Users/Marcello/Downloads/Quantum-GIS-master/build
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Those people who most want to rule people are, ipso-facto, those least suited to do it."
> - A rule of the universe, from the HitchHiker's Guide to the Galaxy
