[Qgis-user] Column selection in Styles dialog breaks styles in latest master
Nathan Woodrow madmanwoo at gmail.com
Thu Jul 11 21:08:21 PDT 2013
Hey Nathanael,
The behaviour of the renderer hasn't changed between 1.8 and 2.0. You can
still add new values by changing the column and pressing classify.  It will
ask you if you want to delete what is there or add to it.
The renderer will look in the selected column for each value, so if it's
set to "highway" but you have values like "bikepath" that isn't going to
match.
You can need to classify based on two columns I would use the rule based
rendering.
- Nathan
On Fri, Jul 12, 2013 at 1:50 PM, Nathanael Boehm <nboehm at purecaffeine.com>wrote:
> Am I confused?
> Just updated to the latest master build this morning and I was working on
> styling some OpenStreetMap data and it was only applying styles to the
> values in the Categorised list for the column selected in the drop-down …
> for example highway, waterway etc … so if I had styles applied to the
> values of "stream" and "river" and then changed the drop-down to "highways"
> to add more classifications for footways, roads etc then the waterway
> styles wouldn't apply.
> Whilst the fundamental design of the Styles dialog hasn't changed I'm sure
> that this behaviour is new … that previously the column drop-down wasn't a
> setting, it was just a precursor to further classifications.
> That said, I'm a novice user and I haven't touched QGIS in a month so it
> could just be my memory or that I've never tried to style both waterways
> and tracks in the one OSM polyline layer …
> Cheers,
> Nathanael Boehm
> UX designer specialising in business web & mobile apps
> www.purecaffeine.com <http://www.purecaffeine.com/professional/>
> Canberra, Australia
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130712/9a5ded74/attachment.html>
