[Qgis-user] Column selection in Styles dialog breaks styles in latest master
Nathanael Boehm nboehm at purecaffeine.com
Thu Jul 11 21:46:55 PDT 2013
Okay thanks Nathan — guess I just didn't notice that behaviour before; will
use rule-based instead otherwise I'm going to end up with 8 OSM layers.
Cheers,
Nathanael Boehm
UX designer specialising in business web & mobile apps
www.purecaffeine.com <http://www.purecaffeine.com/professional/>
Canberra, Australia
On Fri, Jul 12, 2013 at 2:08 PM, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> Hey Nathanael,
> The behaviour of the renderer hasn't changed between 1.8 and 2.0. You can
> still add new values by changing the column and pressing classify.  It will
> ask you if you want to delete what is there or add to it.
> The renderer will look in the selected column for each value, so if it's
> set to "highway" but you have values like "bikepath" that isn't going to
> match.
> You can need to classify based on two columns I would use the rule based
> rendering.
> - Nathan
>  On Fri, Jul 12, 2013 at 1:50 PM, Nathanael Boehm <nboehm at purecaffeine.com
> > wrote:
>>  Am I confused?
>> Just updated to the latest master build this morning and I was working on
>> styling some OpenStreetMap data and it was only applying styles to the
>> values in the Categorised list for the column selected in the drop-down …
>> for example highway, waterway etc … so if I had styles applied to the
>> values of "stream" and "river" and then changed the drop-down to "highways"
>> to add more classifications for footways, roads etc then the waterway
>> styles wouldn't apply.
>> Whilst the fundamental design of the Styles dialog hasn't changed I'm
>> sure that this behaviour is new … that previously the column drop-down
>> wasn't a setting, it was just a precursor to further classifications.
>> That said, I'm a novice user and I haven't touched QGIS in a month so it
>> could just be my memory or that I've never tried to style both waterways
>> and tracks in the one OSM polyline layer …
>> Cheers,
>> Nathanael Boehm
>> Canberra, Australia
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130712/ebaa0625/attachment.html>
