[Qgis-user] QGIS 1.8 - using wms with tiles option drops transparent=true from request
Duarte Carreira DCarreira at edia.pt
Thu Mar 7 05:34:34 PST 2013
I forgot to mention I have a workaround that works when there is no redirection on the wms server...
You can set the following options on the wms connection properties:
1)      Append this to the wms url "?TRANSPARENT=TRUE" or "&TRANSPARENT=TRUE" if your url already has more parameters
2)      Check the option "Ignore GetMap URI reported in capabilities"
This works fine only if your capabilities doc does not point to some other location than the wms url you defined in the connection...
Duarte
De: Duarte Carreira
Enviada: quinta-feira, 7 de Março de 2013 13:23
Para: 'qgis-user at lists.osgeo.org'
Assunto: QGIS 1.8 - using wms with tiles option drops transparent=true from request
Hi.
I'm getting this behaviour when loading a wms layer while setting tile size. This is a non-tiled service. I'm setting this option so I can print within the maximum image size limits imposed by the wms server.
You can see this by setting a background color, pink for example.
Loading the wms layer with tiles covers the pink background.
Loading the same wms layer without setting the tiles size gives me a white transparent background and I can see the pink background. This is the correct expected behavior.
Using Fiddler I can see that with tiles the requests don't have &TRANSPARENT=TRUE appended anymore.
I'm using build f440b60.
Can someone else reproduce this?
Thanks,
Duarte Carreira
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130307/d368519d/attachment.html>
