[Qgis-user] Sextante - Grass modification
magerlin MAP at ramboll.dk
Sat Mar 9 14:19:33 PST 2013
Hi Victor
The Grass v.split takes either a length or a number of vertices as parameter - not both.
So I have split it in two algorithms (attached).
I must add that this is NOT how it is done in the Grass plugin. It only has a v.split algorithm which must contain some logic on parameters (it can also only handle one parameter).
Regards Morten
From: Victor Olaya-3 [via OSGeo.org] [mailto:ml-node+s1560n5035409h18 at n6.nabble.com]
Sent: 20. februar 2013 09:21
To: Morten Agerlin Petersen
Subject: Re: Minor Sextante modifications (grass and sqlite3.dll)
>> 2) If I add more Grass (or SAGA?) modules by making .txt files for the
>> description folders where do I upload or mail theese?
> you can do it the hard way, cloning the git repo and issuing a pull request, or
> simply opening a feature request on the hub, and attaching the command
Or, if that is too complicated, just send them to me by email and I
will check them and add them. :-)
>> 3) Is there a similar place to share .model files of common interest?
> AFAIK not (yet); I'd like to have a general mechanism to share QGIS goodies (not only
> models, but also styles, symbols, etc.), much in line with what happens with users
> plugins.
I would like to have a good set of example models to ship with
SEXTANTE, so feel free to send us your models if you do not mind to
see them included in a future release. That will help new users.
Thanks in advance for your help!
Qgis-user mailing list
[hidden email]</user/SendEmail.jtp?type=node&node=5035409&i=0>
http://lists.osgeo.org/mailman/listinfo/qgis-user
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.n6.nabble.com/Minor-Sextante-modifications-grass-and-sqlite3-dll-tp5035004p5035409.html
To unsubscribe from Minor Sextante modifications (grass and sqlite3.dll), click here<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5035004&code=TUFQQHJhbWJvbGwuZGt8NTAzNTAwNHwtMTI3MTQwNTYxOA==>.
NAML<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
v.split.length.txt (318 bytes) <http://osgeo-org.1560.n6.nabble.com/attachment/5039364/0/v.split.length.txt>
v.split.vert.txt (358 bytes) <http://osgeo-org.1560.n6.nabble.com/attachment/5039364/1/v.split.vert.txt>
Regards Morten
Qgis 1.8.0 Stand alone installer in Win7 64 bit
View this message in context: http://osgeo-org.1560.n6.nabble.com/Sextante-Grass-modification-tp5039364.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130309/f2ef0ffd/attachment.html>
