[Qgis-user] Sextante - Grass modification
Victor Olaya volayaf at gmail.com
Sun Mar 10 10:36:24 PDT 2013
I have already commited your changes. Thanks!
2013/3/9 magerlin <MAP at ramboll.dk>
>  Hi Victor****
> The Grass v.split takes either a length *or* a number of vertices as
> parameter – not both.****
> So I have split it in two algorithms (attached).****
> I must add that this is NOT how it is done in the Grass plugin. It only
> has a v.split algorithm which must contain some logic on parameters (it can
> also only handle one parameter).****
> Regards Morten****
> *From:* Victor Olaya-3 [via OSGeo.org] [mailto:ml-node+[hidden email]<http://user/SendEmail.jtp?type=node&node=5039364&i=0>]
> *Sent:* 20. februar 2013 09:21
> *To:* Morten Agerlin Petersen
> *Subject:* Re: Minor Sextante modifications (grass and sqlite3.dll)****
> >> 2) If I add more Grass (or SAGA?) modules by making .txt files for the
> >> description folders where do I upload or mail theese?
> > you can do it the hard way, cloning the git repo and issuing a pull
> request, or
> > simply opening a feature request on the hub, and attaching the command
> Or, if that is too complicated, just send them to me by email and I
> will check them and add them. :-)
> >> 3) Is there a similar place to share .model files of common interest?
> > AFAIK not (yet); I'd like to have a general mechanism to share QGIS
> goodies (not only
> > models, but also styles, symbols, etc.), much in line with what happens
> with users
> > plugins.
> I would like to have a good set of example models to ship with
> SEXTANTE, so feel free to send us your models if you do not mind to
> see them included in a future release. That will help new users.
> Thanks in advance for your help!
> Qgis-user mailing list
> [hidden email] <http://user/SendEmail.jtp?type=node&node=5035409&i=0>
> *If you reply to this email, your message will be added to the discussion
> below:*
> http://osgeo-org.1560.n6.nabble.com/Minor-Sextante-modifications-grass-and-sqlite3-dll-tp5035004p5035409.html
> To unsubscribe from Minor Sextante modifications (grass and sqlite3.dll), click
> here.
> NAML<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> *v.split.length.txt* (318 bytes) Download Attachment<http://osgeo-org.1560.n6.nabble.com/attachment/5039364/0/v.split.length.txt>
> *v.split.vert.txt* (358 bytes) Download Attachment<http://osgeo-org.1560.n6.nabble.com/attachment/5039364/1/v.split.vert.txt>
>  Regards Morten
> Qgis 1.8.0 Stand alone installer in Win7 64 bit
> View this message in context: Sextante - Grass modification<http://osgeo-org.1560.n6.nabble.com/Sextante-Grass-modification-tp5039364.html>
> Sent from the Quantum GIS - User mailing list archive<http://osgeo-org.1560.n6.nabble.com/Quantum-GIS-User-f4125267.html>at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130310/378a02fc/attachment.html>
