[Qgis-user] Map graticules in QGIS
Andre Joost andre+joost at nurfuerspam.de
Sun Mar 10 22:15:10 PDT 2013
Am 10.03.2013 23:49, schrieb Lester Anderson:
> I have tried the route you suggested. I am working on Antarctic data, so
> generated a vector grid for 0-360 in X (at 10 degrees) and latitude (-90 to
> -60) in 10 degrees. That all worked fine in WGS84. However, reprojecting to
> Antarctic Polarstreographic did not project correctly with less than half
> the meridians and no latitudes.
I do the vectorgrid with polygons instead of lines, and the result looks
quiet good, depending on the grid width.
Greetings,
Andre Joost
