[Qgis-user] Qgis-user Digest, Vol 85, Issue 32
Bernd Laskowski Bernd.Laskowski at Reichshof.de
Wed Mar 13 08:53:57 PDT 2013
I've got the data in a table.
Apparently they are wrong (more than 59 minutes).
I'll check them.
Thanks a lot
Regards
Bernd
Send Qgis-user mailing list submissions to
	qgis-user at lists.osgeo.org
To subscribe or unsubscribe via the World Wide Web, visit
	http://lists.osgeo.org/mailman/listinfo/qgis-user
or, via email, send a message with subject or body 'help' to
	qgis-user-request at lists.osgeo.org
You can reach the person managing the list at
	qgis-user-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Qgis-user digest..."
Today's Topics:
    1. Re: convert UTM_UPS data from gps to decimal degrees
       (Gerardo Jimenez)
    2. Re: convert UTM_UPS data from gps to decimal degrees (G. Allegri)
Message: 1
Date: Wed, 13 Mar 2013 11:00:51 -0400
To: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
Subject: Re: [Qgis-user] convert UTM_UPS data from gps to decimal
	degrees
Message-ID: <SNT002-W149261646CE3FF63F27528695E30 at phx.gbl>
Content-Type: text/plain; charset="iso-8859-1"
Hi
First, your data is kind of rare, you can not have more than 60 minutes or more than 60 seconds (50?96'06''2N for instance). How did you get this info? a gpx file or your field notes? (usually a gps stores data in lat lon wgs84, no matter how you configure the unit to display the data).  If you want to covert lat lon data in to utm you have to make two things. A) Convert your readings in to decimal degrees in a spreadsheet.
You have to capture in separate columns the arguments for degrees minutes and seconds. Then the formula will bedeg+(min/60)+(sec/3600). Keep in mind that the formula for your longitudes must be: -1*(deg+(min/60)+(sec/3600)) since your data is in the western hemisphere.  Copy the values of the formulas in a new file and label the first row lat lon accordingly. You can include an identifier. Save the file as CSV comma delimited.
B1) Load the CSV file in Qgis using the "add delimited text layer" plugin.  Once the data is on the screen you have to select the layer and save is as shp or comma separated value, that your choice. You have to choose also the coordinate system of your choice for the new layer.
B2) Or you can also use GPS babel (free). It can read a csv file and convert it to utm. Just check the documentation for the supported datums
Gerardo Jim?nez Delgado
Instituto de Investigaciones Antropol?gicas
Universidad Nacional Aut?noma de M?xico
Ciudad Universitaria s/n
Coyoacan 04510
Mexico City
Mexico
56 22 95 16
Date: Wed, 13 Mar 2013 14:49:47 +0100
To: Bernd.Laskowski at reichshof.de
CC: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] convert UTM_UPS data from gps to decimal degrees
I'm not sure if they are milliseconds.O would try to divide the last digits by 3600000 (and sum to the rest)
2013/3/13 Bernd Laskowski <Bernd.Laskowski at reichshof.de>
     Hi Giovanni,
       If I try this the points are fare away from the real point.
       What about the Number rigth from seconds (f.e. 2 or 9)?
       Regards
       Bernd
       Am 13.03.2013 14:09, schrieb G. Allegri:
     degrees+minutes/60+seconds/3600
       e.g.
       50+(96/60)+(6/3600) = 51.601666...
       giovanni
              Hi all,
               how I can convert data in following format to get decimal
               degrees.
               50?96'06''2N/7?70'18''3O
               50?96'39''9N/7?68'56''3O
               50?95'72''9N/7?68'00''5O
               Garmin GPS configuration:
               Positionsformat: UTM UPS
               Kartenbezugssystem: WGS84
               Kartensph?roid: WGS84
               Would WGS84/UPS North (EPSG 32661) in Qgis the correct
               coordinate system?
               I use ETRS89 (EPSG 25832)
               Regards
                   Bernd
             Qgis-user at lists.osgeo.org
         Giovanni
           Allegri
         website: http://giovanniallegri.it
           GEO+ geomatica in
               Italia http://bit.ly/GEOplus
Gemeinde Reichshof
I/10 Zentrale Verwaltung
Bernd Laskowski
Hauptstra?e 12
51580 Reichshof - Denklingen
Tel.: (02296) 801 - 313
Fax: (02296) 801 - 395
E-mail: Bernd.Laskowski at Reichshof.de
Der Inhalt dieser E-Mail ist ausschlie?lich f?r den bezeichneten Adressaten bestimmt. Wenn Sie nicht der vorgesehene Adressat dieser E-Mail oder dessen Vertreter sein sollten, so beachten Sie bitte, dass jede Form der Kenntnisnahme, Ver?ffentlichung, Vervielf?ltigung oder Weitergabe des Inhalts dieser E-Mail unzul?ssig ist. Wir bitten Sie, sich in diesem Fall mit dem Absender der E-Mail in Verbindung zu setzen.
Bei Abwesenheit des Adressaten, an den Sie eine E-Mail gerichtet haben, kann diese automatisch an dessen Vertreter weitergeleitet werden. Wir m?chten Sie au?erdem darauf hinweisen, dass die Kommunikation per E-Mail ohne Authentifizierung und Verschl?sselung unsicher ist, da f?r unberechtigte Dritte grunds?tzlich die M?glichkeit der Kenntnisnahme und Manipulation besteht. Wir ?bernehmen deshalb keine Verantwortung f?r den Inhalt dieser Nachricht, da eine Manipulation nicht ausgeschlossen werden kann. Obwohl wir alle angemessenen Vorkehrungen getroffen haben, um sicherzustellen, dass Anlagen dieser E-Mail Virus-gepr?ft sind, empfehlen wir dennoch, anh?ngende Dateien vor dem ?ffnen durch Ihr eigenes Virus-Programm zu pr?fen, da wir keinerlei Haftung f?r Sch?den ?bernehmen, die infolge etwaiger Software-Viren entstehen k?nnten.
Giovanni Allegri
GEO+ geomatica in Italia http://bit.ly/GEOplus
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130313/97e43afd/attachment-0001.html>
Message: 2
Date: Wed, 13 Mar 2013 16:04:15 +0100
To: Gerardo Jimenez <gejst5 at hotmail.com>
Cc: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
	degrees
Message-ID:
	<CAB4g1=xVyxaXLx72Qp_xfyd_WGfVEsaU9DPx-t4q4S=Xt7hmww at mail.gmail.com>
Gerardo, it was already explained... the problem with its coordinates is
that they don't overlay on its map. I suppose its map is in a different CRS
and the on the fly reprojection don't fit well because of trnasformations
parameters.
Anyway, yes, the "milliseconds" are unusale...
giovanni
2013/3/13 Gerardo Jimenez <gejst5 at hotmail.com>
> Hi
> more than 60 seconds (50?*96*'06''2N for instance). How did you get this
> Coyoacan 04510 Mexico City
> Mexico 56 22 95 16
> From: giohappy at gmail.com
>  Hi Giovanni,
> Regards
> Bernd
>  e.g.
>  giovanni
>  Hi all,
> how I can convert data in following format to get decimal degrees.
> Would WGS84/UPS North (EPSG 32661) in Qgis the correct coordinate system?
> Regards
> Bernd
> Giovanni Allegri
> Gemeinde Reichshof
> Bernd Laskowski
> Hauptstra?e 12
> Giovanni Allegri
> _______________________________________________ Qgis-user mailing list
Giovanni Allegri
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130313/a3725007/attachment.html>
End of Qgis-user Digest, Vol 85, Issue 32
