[Qgis-user] DD to meters
José Pedro Santos zpsantos1 at hotmail.com
Fri Mar 15 09:31:52 PDT 2013
This question as already reply in this list:
I forward the email:
1 - Put your data in a spreadsheet (like OO Calc)
2 - Transform DMS coordinates to decimal deegrees (deegree+minutes/60+seconds/3600)
3 - Export as CSV
4 - Import in QGis using the "Comma Separated Value" plugin, which
is included by default in QGis. It will ask you the separator you used
for the CSV (e.g. tab, comma, etc.) and it will try to guess the lat/lon
 fields, but if it will be wrong you can set
them manually.
5 - In case QGis won't set the CRS correctly, you can do it from
the Layer Properties panel, and set it to WGS84 (I suppose it's the CRS
of your coordinates)
giovanni
Best Regards,
José Santos
Date: Fri, 15 Mar 2013 16:24:53 +0100
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] DD to meters
I think you first must know what kind of degrees you have or have it defined in a layer you add to QGIS. If you under 'Settings-->Option" chose a metric coordidant system (Fore instance UTM N33 (as in Sweden)) and then check *on the fly reprojection' so do added layer in other types, for instance from a GPS and WGS84. Metrical coordinate systems as UTM are in different zones on the earth in both North hemispere and south hemispere because the earth are not an 'perfect elipsoid'. Very neare the poles you need yet another projection. There are often also national metrical grid, depending on in which country or region you are in and even smaller region, if you need very good precision, eg less than meters.
Hope this help /Cheers
2013/3/15 adamu eloji <aeloji60 at yahoo.com>
Dear All,
             How can Decimal  Degree be converted to meters.Any idea from member.
ThanksAdamu
      From: "qgis-user-request at lists.osgeo.org" <qgis-user-request at lists.osgeo.org>
 Sent: Wednesday, March 13, 2013 3:38 PM
 Subject: Qgis-user Digest, Vol 85, Issue 31
Send Qgis-user mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
    http://lists.osgeo.org/mailman/listinfo/qgis-user
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
    qgis-user-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Qgis-user digest..."
Today's Topics:
   1. Re: convert UTM_UPS data from gps to decimal
 degrees
      (Bernd Laskowski)
   2. Re: convert UTM_UPS data from gps to decimal degrees (G. Allegri)
Message: 1
Date: Wed, 13 Mar 2013 15:28:32 +0100
From: Bernd Laskowski <Bernd.Laskowski at Reichshof.de>
Subject: Re: [Qgis-user] convert UTM_UPS data from gps to decimal
    degrees
Message-ID: <51408D10.2090603 at Reichshof.de>
Content-Type: text/plain; charset="iso-8859-1"; Format="flowed"
I tryed again with milliseconds but the result is nearly the same.
The real Point is
 about 80 km away.
The UTM UPS WGS84 koordinate system seems to be another than usual WGS84.
Regards
Bernd
Am 13.03.2013 14:49, schrieb G. Allegri:
> I'm not sure if they are milliseconds.
> O would try to divide the last digits by 3600000 (and sum to the rest)
> 2013/3/13 Bernd Laskowski <Bernd.Laskowski at reichshof.de
> <mailto:Bernd.Laskowski at reichshof.de>>
>     Hi Giovanni,
>     If I try this the points are fare away from the real point.
>     What about the Number rigth from seconds (f.e. 2 or 9)?
>     Regards
>     Bernd
>     Am 13.03.2013 14:09,
 schrieb G. Allegri:
>>     degrees+minutes/60+seconds/3600
>>     e.g.
>>     50+(96/60)+(6/3600) = 51.601666...
>>     giovanni
>>         Hi all,
>>         how I can convert data in following format to get decimal
>>         degrees.
>>         50?96'06''2N/7?70'18''3O
 50?96'39''9N/7?68'56''3O
>>         50?95'72''9N/7?68'00''5O
>>         Garmin GPS configuration:
>>         Positionsformat: UTM UPS
>>         Kartenbezugssystem: WGS84
>>         Kartensph?roid: WGS84
>>         Would WGS84/UPS North (EPSG 32661) in Qgis the correct
>>         coordinate system?
>>         I use ETRS89 (EPSG 25832)
>>         Regards
>>         Bernd
>>         _______________________________________________
>>         Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>     Giovanni Allegri
>>     website: http://giovanniallegri.it <http://giovanniallegri.it>
>>     GEO+ geomatica in Italia http://bit.ly/GEOplus
>     Gemeinde Reichshof
>     I/10
 Zentrale Verwaltung
>     Bernd Laskowski
>     Hauptstra?e 12
>     51580 Reichshof - Denklingen
>     Tel.: (02296) 801 - 313
>     Fax: (02296) 801 - 395
>     E-mail:Bernd.Laskowski at Reichshof.de  <mailto:Bernd.Laskowski at Reichshof.de>
>     Der Inhalt dieser E-Mail ist ausschlie?lich f?r den bezeichneten Adressaten bestimmt. Wenn Sie nicht der vorgesehene Adressat dieser E-Mail oder dessen Vertreter sein sollten, so beachten Sie bitte, dass jede Form der Kenntnisnahme, Ver?ffentlichung, Vervielf?ltigung oder Weitergabe des Inhalts dieser E-Mail unzul?ssig ist. Wir bitten Sie, sich in diesem Fall mit dem Absender der E-Mail in
 Verbindung zu setzen.
>     Bei Abwesenheit des Adressaten, an den Sie eine E-Mail gerichtet haben, kann diese automatisch an dessen Vertreter weitergeleitet werden. Wir m?chten Sie au?erdem darauf hinweisen, dass die Kommunikation per E-Mail ohne Authentifizierung und Verschl?sselung unsicher ist, da f?r unberechtigte Dritte grunds?tzlich die M?glichkeit der Kenntnisnahme und Manipulation besteht. Wir ?bernehmen deshalb keine Verantwortung f?r den Inhalt dieser Nachricht, da eine Manipulation nicht ausgeschlossen werden kann. Obwohl wir alle angemessenen Vorkehrungen getroffen haben, um sicherzustellen, dass Anlagen dieser E-Mail Virus-gepr?ft sind, empfehlen wir dennoch, anh?ngende Dateien vor dem ?ffnen durch Ihr eigenes Virus-Programm zu pr?fen, da wir keinerlei Haftung f?r Sch?den ?bernehmen, die infolge etwaiger Software-Viren entstehen k?nnten.
> Giovanni Allegri
Gemeinde Reichshof
I/10 Zentrale Verwaltung
Bernd Laskowski
Hauptstra?e 12
E-mail: Bernd.Laskowski at Reichshof.de
 Weitergabe des Inhalts dieser E-Mail unzul?ssig ist. Wir bitten Sie, sich in diesem Fall mit dem Absender der E-Mail in Verbindung zu setzen.
 entstehen k?nnten.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130313/258fcdbb/attachment-0001.html>
Message: 2
Date: Wed, 13 Mar 2013 15:38:27 +0100
To: Bernd Laskowski <Bernd.Laskowski at reichshof.de>
Cc: qgis-user at lists.osgeo.org
 degrees
Message-ID:
    <CAB4g1=z8AfAnD+_3cV666jZia0iUjNi-wr9uG4b+RtSdgCnAcg at mail.gmail.com>
UTM/UPS are prjections which can be used to translate WGS84 lat/lon
coordinates to planar coordinates.
UTM is used for latitudes upt to 80 deegree (more or less), while UPS
(North/South) are used for higher latitudes, polar regions.
Coordinates in UTM/UPS would be metrics, while you're reporting lat/lon
coordinates, which should be the WGS84 raw coordinates from the GPS.
What is the CRS of the base map tou're using to test the correctness of the
coordinates?
2013/3/13 Bernd Laskowski <Bernd.Laskowski at reichshof.de>
>  I tryed again with
> The real Point is about 80 km away.
> Regards
> Bernd
>>  Hi Giovanni,
>> Regards
>> Bernd
>> Am 13.03.2013 14:09, schrieb G. Allegri:
>>  e.g.
>>  giovanni
>>>  Hi all,
>>> how I can convert data in following format to get decimal degrees.
>>> Would WGS84/UPS North (EPSG 32661) in Qgis the correct coordinate system?
>>> I use ETRS89 (EPSG
 25832)
>>> Regards
>>> Bernd
>> Giovanni Allegri
 Gemeinde Reichshof
>> Bernd Laskowski
>> Hauptstra?e 12
>> Der Inhalt dieser E-Mail ist ausschlie?lich f?r den bezeichneten Adressaten bestimmt. Wenn Sie nicht der vorgesehene Adressat dieser E-Mail oder dessen Vertreter sein sollten, so beachten Sie bitte, dass jede Form der Kenntnisnahme, Ver?ffentlichung, Vervielf?ltigung oder Weitergabe des Inhalts dieser E-Mail unzul?ssig ist. Wir bitten Sie, sich in diesem Fall mit dem Absender der E-Mail in Verbindung zu setzen.
> Giovanni Allegri
> Gemeinde Reichshof
> Bernd Laskowski
> Hauptstra?e 12
> Bei
Giovanni Allegri
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130313/e34b6b50/attachment.html>
End of Qgis-user Digest, Vol 85, Issue 31
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130315/c7ccb1b1/attachment.html>
