[Qgis-user] DD to meters
Mats Elfström mats.elfstrom at gmail.com
Sat Mar 16 10:06:40 PDT 2013
Hi Adamu!
Can you convert a hare to a tortoise? No. The question is pointless.
And asking to convert decimal degrees to meters is equally pointless.
But let me guess what you are really asking:
Can you transform or translate GIS data with decimal degree coordinates
from one coordinate system to another coordinate system where meters is the
coordinate unit?
Probably, yes. But to do that, you will most likely need:
1 to know the definitions for the two coordinate systems, their EPSG codes
or equal.
2 the transformation parameters in a form that your software can use. Note
that conversion between different geodetic datums is tricky geodetic
arithmetic, and can not be solved by simple 2D geometry.
3 qualified software to read and write your data sets in the format you
need.
As for the last point, you may like to take a look at the Geographic
Calculator from Blue Marble geographics, or FME from Safe Software.
http://www.bluemarblegeo.com/products/geographic-calculator.php
http://www.safe.com/
Regards, Mats.E
2013/3/15 adamu eloji <aeloji60 at yahoo.com>
> Dear All,
>              How can Decimal  Degree be converted to meters.Any idea from
> member.
> Thanks
> Adamu
> *From:* "qgis-user-request at lists.osgeo.org" <
> qgis-user-request at lists.osgeo.org>
> *To:* qgis-user at lists.osgeo.org
> *Sent:* Wednesday, March 13, 2013 3:38 PM
> *Subject:* Qgis-user Digest, Vol 85, Issue 31
> Send Qgis-user mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
>     http://lists.osgeo.org/mailman/listinfo/qgis-user
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>     qgis-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Qgis-user digest..."
> Today's Topics:
>   1. Re: convert UTM_UPS data from gps to decimal degrees
>       (Bernd Laskowski)
>   2. Re: convert UTM_UPS data from gps to decimal degrees (G. Allegri)
> Message: 1
> Date: Wed, 13 Mar 2013 15:28:32 +0100
> From: Bernd Laskowski <Bernd.Laskowski at Reichshof.de>
> To: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] convert UTM_UPS data from gps to decimal
>     degrees
> Message-ID: <51408D10.2090603 at Reichshof.de>
> Content-Type: text/plain; charset="iso-8859-1"; Format="flowed"
> I tryed again with milliseconds but the result is nearly the same.
> The real Point is about 80 km away.
> The UTM UPS WGS84 koordinate system seems to be another than usual WGS84.
> Regards
> Bernd
> Am 13.03.2013 14:49, schrieb G. Allegri:
> > I'm not sure if they are milliseconds.
> > O would try to divide the last digits by 3600000 (and sum to the rest)
> > 2013/3/13 Bernd Laskowski <Bernd.Laskowski at reichshof.de
> > <mailto:Bernd.Laskowski at reichshof.de>>
> >    Hi Giovanni,
> >    If I try this the points are fare away from the real point.
> >    What about the Number rigth from seconds (f.e. 2 or 9)?
> >    Regards
> >    Bernd
> >    Am 13.03.2013 14:09, schrieb G. Allegri:
> >>    degrees+minutes/60+seconds/3600
> >>    e.g.
> >>    50+(96/60)+(6/3600) = 51.601666...
> >>    giovanni
> >>        Hi all,
> >>        how I can convert data in following format to get decimal
> >>        degrees.
> >>        50?96'06''2N/7?70'18''3O
> >>        50?96'39''9N/7?68'56''3O
> >>        50?95'72''9N/7?68'00''5O
> >>        Garmin GPS configuration:
> >>        Positionsformat: UTM UPS
> >>        Kartenbezugssystem: WGS84
> >>        Kartensph?roid: WGS84
> >>        Would WGS84/UPS North (EPSG 32661) in Qgis the correct
> >>        coordinate system?
> >>        I use ETRS89 (EPSG 25832)
> >>        Regards
> >>        Bernd
> >>        _______________________________________________
> >>        Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> >>    Giovanni Allegri
> >>    website: http://giovanniallegri.it <http://giovanniallegri.it>
> >>    GEO+ geomatica in Italia http://bit.ly/GEOplus
> >    Gemeinde Reichshof
> >    I/10 Zentrale Verwaltung
> >    Bernd Laskowski
> >    Hauptstra?e 12
> >    51580 Reichshof - Denklingen
> >    Tel.: (02296) 801 - 313
> >    Fax: (02296) 801 - 395
> >    E-mail:Bernd.Laskowski at Reichshof.de  <mailto:
> >    Der Inhalt dieser E-Mail ist ausschlie?lich f?r den bezeichneten
> Adressaten bestimmt. Wenn Sie nicht der vorgesehene Adressat dieser E-Mail
> oder dessen Vertreter sein sollten, so beachten Sie bitte, dass jede Form
> der Kenntnisnahme, Ver?ffentlichung, Vervielf?ltigung oder Weitergabe des
> Inhalts dieser E-Mail unzul?ssig ist. Wir bitten Sie, sich in diesem Fall
> mit dem Absender der E-Mail in Verbindung zu setzen.
> >    Bei Abwesenheit des Adressaten, an den Sie eine E-Mail gerichtet
> haben, kann diese automatisch an dessen Vertreter weitergeleitet werden.
> Wir m?chten Sie au?erdem darauf hinweisen, dass die Kommunikation per
> E-Mail ohne Authentifizierung und Verschl?sselung unsicher ist, da f?r
> unberechtigte Dritte grunds?tzlich die M?glichkeit der Kenntnisnahme und
> Manipulation besteht. Wir ?bernehmen deshalb keine Verantwortung f?r den
> Inhalt dieser Nachricht, da eine Manipulation nicht ausgeschlossen werden
> kann. Obwohl wir alle angemessenen Vorkehrungen getroffen haben, um
> sicherzustellen, dass Anlagen dieser E-Mail Virus-gepr?ft sind, empfehlen
> wir dennoch, anh?ngende Dateien vor dem ?ffnen durch Ihr eigenes
> Virus-Programm zu pr?fen, da wir keinerlei Haftung f?r Sch?den ?bernehmen,
> die infolge etwaiger Software-Viren entstehen k?nnten.
> > Giovanni Allegri
> Gemeinde Reichshof
> Bernd Laskowski
> Hauptstra?e 12
> E-mail: Bernd.Laskowski at Reichshof.de
> Bei Abwesenheit des Adressaten, an den Sie eine E-Mail gerichtet haben,
> kann diese automatisch an dessen Vertreter weitergeleitet werden. Wir
> m?chten Sie au?erdem darauf hinweisen, dass die Kommunikation per E-Mail
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20130313/258fcdbb/attachment-0001.html
> Message: 2
> Date: Wed, 13 Mar 2013 15:38:27 +0100
> From: "G. Allegri" <giohappy at gmail.com>
> To: Bernd Laskowski <Bernd.Laskowski at reichshof.de>
> Cc: qgis-user at lists.osgeo.org
>     degrees
> Message-ID:
>     <CAB4g1=z8AfAnD+_3cV666jZia0iUjNi-wr9uG4b+RtSdgCnAcg at mail.gmail.com>
> UTM/UPS are prjections which can be used to translate WGS84 lat/lon
> coordinates to planar coordinates.
> UTM is used for latitudes upt to 80 deegree (more or less), while UPS
> (North/South) are used for higher latitudes, polar regions.
> Coordinates in UTM/UPS would be metrics, while you're reporting lat/lon
> coordinates, which should be the WGS84 raw coordinates from the GPS.
> What is the CRS of the base map tou're using to test the correctness of the
> coordinates?
> 2013/3/13 Bernd Laskowski <Bernd.Laskowski at reichshof.de>
> > Regards
> > Bernd
> >>  Hi Giovanni,
> >> Regards
> >> Bernd
> >>  e.g.
> >>  giovanni
> >>>  Hi all,
> >>> how I can convert data in following format to get decimal degrees.
> >>> Would WGS84/UPS North (EPSG 32661) in Qgis the correct coordinate
> system?
> >>> Regards
> >>> Bernd
> >> Giovanni Allegri
> >> Gemeinde Reichshof
> >> Bernd Laskowski
> >> Hauptstra?e 12
> > Giovanni Allegri
> > Gemeinde Reichshof
> > Bernd Laskowski
> > Hauptstra?e 12
> Giovanni Allegri
> URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20130313/e34b6b50/attachment.html
> End of Qgis-user Digest, Vol 85, Issue 31
Mats Elfström, Väpplingvägen 21, SE-227 38 LUND, Sweden
tel: +46 46 145959 / mob: +46 70 595 39 35
alt e-mail: mats.elfstrom at telia.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130316/61426ba7/attachment.html>
