[Qgis-user] How to get the UTM coordinates in my attribut table after projected a point filefrom geographics coordinates to UTM
Manuel Spínola mspinola10 at gmail.com
Mon Mar 18 10:21:30 PDT 2013
Thank you very much.  The use of field calculator works.
Manuel
2013/3/18 Andre Joost <andre+joost at nurfuerspam.de>
> Am 18.03.2013 14:16, schrieb Manuel Spínola:
>  Dear list members,
>> I projected a point file from geographics coordinates to UTM.  How can I
>> get the UTM coordinates in the attribute table?
> Not sure what was suggested in Spanish, but I use the field calculator in
> the attribute table for such things:
> Change to edit mode
> Start Field calculator
> Give E or X as new field name
> Field Type should be set to real
> accuracy to 1 (or more for degrees)
> under "Geometry", select $x entry
> OK
> Same for $y values.
> After Saving, the values get rounded to the accuracy you gave.
> HTH,
> André Joost
> ______________________________**_________________
> Qgis-user mailing list
> http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
*Manuel Spínola, Ph.D.*
Instituto Internacional en Conservación y Manejo de Vida Silvestre
Universidad Nacional
Apartado 1350-3000
Heredia
COSTA RICA
mspinola at una.ac.cr
Teléfono: (506) 2277-3598
Fax: (506) 2237-7036
Personal website: Lobito de río <https://sites.google.com/site/lobitoderio/>
Institutional website: ICOMVIS <http://www.icomvis.una.ac.cr/>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130318/36a4d02d/attachment.html>
