[Qgis-user] QGIS install fail on Ubuntu 12.04
Lee muellerl at gmail.com
Mon Mar 18 11:47:33 PDT 2013
No dice. Plus, I'd think that "sudo qgis" might solve that issue, but it
doesn't.
In either case, near the bottom of the second link is this statement:
"OP said they couldn't install 90% of plugins - I found, after upgrade to
Ubuntu 12.04, that only the core plugins (C++?) were available, to get all
the python plug-ins as well, you need to install the package python-qgis as
well."
This is what I attempted before this whole odyssey began. "sudo apt-get
install python-qgis." Unfortunately, this generates the following unmet
dependency errors:
The following packages have unmet dependencies:
 python-qgis : Depends: python-qt4 (>= 4.1.0) but it is not going to be
installed
               Depends: python-qgis-common (= 1.8.0-1~precise3) but
1.9.0+git20130316+5d42734~precise1 is to be installed
E: Unable to correct problems, you have held broken packages.
All the best,
Lee
ISA Certified Arborist MI-4148A
Registered Forester #46043
On Mon, Mar 18, 2013 at 2:41 PM, Andre Joost <andre+joost at nurfuerspam.de>wrote:
> Am 18.03.2013 19:26, schrieb Lee:
>  QGIS launches, but I still don't have the capability to fetch plugins.
>> This is the error I was getting originally. So at the very least, QGIS
>> works again, but we haven't fixed my original problem. Other thoughts?
> Maybe you stuck with write permissions?
> <http://gis.stackexchange.com/**questions/28587/plugins-are-**
> not-installed-in-qgis-1-8-0-**lisboa<http://gis.stackexchange.com/questions/28587/plugins-are-not-installed-in-qgis-1-8-0-lisboa>
> <http://gis.stackexchange.com/**questions/24352/why-cant-i-**
> add-most-plugins-under-ubuntu-**12-04<http://gis.stackexchange.com/questions/24352/why-cant-i-add-most-plugins-under-ubuntu-12-04>
> HTH,
> André Joost
> ______________________________**_________________
> Qgis-user mailing list
> http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130318/b50ab1bd/attachment.html>
