[Qgis-user] QGIS install fail on Ubuntu 12.04
Andre Joost andre+joost at nurfuerspam.de
Mon Mar 18 11:52:30 PDT 2013
Am 18.03.2013 19:47, schrieb Lee:
> No dice. Plus, I'd think that "sudo qgis" might solve that issue, but it
> doesn't.
I just tried to install plugins, got the error message, did the sudo
(with -R), and it went through.
> In either case, near the bottom of the second link is this statement:
> "OP said they couldn't install 90% of plugins - I found, after upgrade to
> Ubuntu 12.04, that only the core plugins (C++?) were available, to get all
> the python plug-ins as well, you need to install the package python-qgis as
> well."
> This is what I attempted before this whole odyssey began. "sudo apt-get
> install python-qgis." Unfortunately, this generates the following unmet
> dependency errors:
> The following packages have unmet dependencies:
>   python-qgis : Depends: python-qt4 (>= 4.1.0) but it is not going to be
> installed
>                 Depends: python-qgis-common (= 1.8.0-1~precise3) but
> 1.9.0+git20130316+5d42734~precise1 is to be installed
> E: Unable to correct problems, you have held broken packages.
Looks like the python-qgis is to be installed from the wrong place. And
python-qt4 seems somehow wrong also.
Greetings,
André Joost
