[Qgis-user] OSM import: missing ways
    Andre Joost
    andre+joost at nurfuerspam.de
    Wed Mar 20 08:48:18 PDT 2013
Am 20.03.2013 16:33, schrieb Andre Joost:
> The difference is that Openstreetmap has recently hit the 2^31-Limit for
> 32-bit integers for node IDs. The old Openstreetmap plugin you use is
> not designed for 64-bit-integers, which spoils the import of the nodes,
> making the way invisible.
> There is a new Openstreetmap plugin on the way, but only in QGIS Master
> and the upcoming QGIS 2.0.
EDIT: You can still use the spatialite tools (outside QGIS) to import
OSM data in a spatialite database and work with that.
Greetings,
André Joost
