[Qgis-user] Problems with RGB composition
José Pedro Santos zpsantos1 at hotmail.com
Wed Mar 20 08:52:23 PDT 2013
Hi Bernardo,
Why don't use the Orfeo Toolbox inside Sextante instead of using the RGB plugin? I think also SAGA GIS have some algorithms to do that. I never used that plugin.
Best Regards,
José Santos
Date: Wed, 20 Mar 2013 06:27:15 -0700
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] Problems with RGB composition
Dear all,
I am working with QGIS version 1.8.0 (Lisboa) and trying to compose a layer using three different satellite images (red, green, and blue) using "RGB Composition" plugin.
However, I have a problem every time I try to unify this images. I have already tried it using different images from different sources, what makes me think that the problem is with QGIS. Furthermore, a friend of mine were able to make the composition using ArcGIS.
I have already seen this problem reported in some forums, but with no answers of how to fix it.
Could you please help me with that? Do you have any insight about that?
Thank you very much.
Here I show the problem:
  File "/home/berci/.qgis//python/plugins/rgb/Rgb.py", line 49, in makergb
    composite.rgb(str(self.pluginGui.comboBox_3.currentText()),str(self.pluginGui.comboBox_4.currentText()),str(self.pluginGui.comboBox_5.currentText()),str(self.pluginGui.lineEdit.text()))
  File "/home/berci/.qgis//python/plugins/rgb/composite.py", line 18, in rgb
    x=r.RasterXSize
AttributeError: 'NoneType' object has no attribute 'RasterXSize'
Versão do Python:
2.7.3 (default, Aug  1 2012, 05:27:35)
[GCC 4.6.3]
Versão do QGIS
1.8.0-Lisboa Lisboa, exported
Caminho para o Python: ['/usr/share/qgis/python', '/home/berci/.qgis//python', '/home/berci/.qgis//python/plugins', '/usr/share/qgis/python/plugins', '/usr/lib/python2.7',
 '/usr/lib/python2.7/plat-linux2', '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old', '/usr/lib/python2.7/lib-dynload', '/usr/local/lib/python2.7/dist-packages', '/usr/lib/python2.7/dist-packages', '/usr/lib/python2.7/dist-packages/PIL', '/usr/lib/python2.7/dist-packages/gst-0.10', '/usr/lib/python2.7/dist-packages/gtk-2.0', '/usr/lib/pymodules/python2.7', '/usr/lib/python2.7/dist-packages/ubuntu-sso-client', '/usr/lib/python2.7/dist-packages/ubuntuone-client', '/usr/lib/python2.7/dist-packages/ubuntuone-control-panel', '/usr/lib/python2.7/dist-packages/ubuntuone-couch', '/usr/lib/python2.7/dist-packages/ubuntuone-installer', '/usr/lib/python2.7/dist-packages/ubuntuone-storage-protocol', '/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode', '/usr/share/qgis/python', '/usr/share/qgis/python/plugins/fTools/tools', '/usr/share/qgis/python']
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130320/e274ca39/attachment.html>
