[Qgis-user] Text Size in WMS maps
Marco Hugentobler marco.hugentobler at sourcepole.ch
Fri Mar 22 05:27:06 PDT 2013
QGIS as WMS clients supports the dpi syntax for QGIS server / UMN
mapserver / geoserver (but afaik in 1.8 only the QGIS server syntax is
supported).
Regards,
Marco
On 22.03.2013 13:16, Andreas Neumann wrote:
> What server is the WMS? Many servers support the DPI parameter nowadays
> (not in the OGC standard - but most servers implement them). I know that
> both UMN Mapserver and QGIS server support the DPI parameter.
> Would be nice if the QGIS WMS client would support it as well - esp.
> when printing/exporting the WMS.
> Andreas
> Am 22.03.2013 12:38, schrieb magerlin:
>> Hi
>> I use a cadastral map from a wms server. The wms map includes some text on
>> each parcel.
>> The text size is fine both on map canvas and in the map composer window.
>> But when I save as either pdf or jpeg from the print composer the font size
>> in the resulting file is dependent on how many dpi I save in.
>> Only when saving in screen resolution I get text in a readable size while
>> saving in a more normal resolution of 300 dpi gives text so small that you
>> can't read it.
>> Anything to do about that?
>> Or is it simply wrong to deliver text as a part of a WMS map?
>> Regards Morten
>> Qgis 1.8.0 Stand alone installer in Win7 64 bit
>> View this message in context: http://osgeo-org.1560.n6.nabble.com/Text-Size-in-WMS-maps-tp5042320.html
>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Dr. Marco Hugentobler
Sourcepole -  Linux & Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
