[Qgis-user] Label with HTML-expressions
Bernhard Ströbl bernhard.stroebl at jena.de
Thu Mar 28 05:19:12 PDT 2013
Hi Antonio,
the popups were merged into qgis-web-client last tuesday, so you should
update your site to the latest version.
If you activate the infoButton and click on a feature a popup opens
displaying all the fields you allowed for display.
If you activate the infoButton and move the mouse over a feature a small
popup opens showing the contents of your infoField: if you use
GetProjectSettings this is the field you assigned in your project as
"map tip display" for the layer. If you use GetCapabilities you need a
field named "tooltip" in your layer (can be an alias)
hope this helps
Bernhard
Am 28.03.2013 12:58, schrieb Antonio Vico:
> Hi Bernhard, thanks for your reply
> I am installed and configured qgis-server and qgis-web-client in debian
> squeeze for testing and work fine, but I don't know how to make popups
> like the link I wrote.
> I am configured GlobalOptions.js and create different
> "qgiswebclient.html" according to the tutorial Publishing multiple
> projects with QGIS Server
> <http://linfiniti.com/2012/02/publishing-multiple-projects-with-qgis-server/>
> at
> (thanks to Tim Sutton for your work) but I don't hanve found
> documentation about popup. My Google search only show popup about
> OpenLayers.
> What files need to be configured for show popup ?
> El 28/03/2013 8:12, Bernhard Ströbl escribió:
>> Hi Antonio,
>> qgis-web-client [1] is a JavaScript webmap client based on GeoExt
>> (which is based on ExtJS and OpenLayers). You do not need any JS
>> yourself, all you need is doing the setup.
>> Bernhard
>> [1] https://github.com/qgis/qgis-web-client
>> Am 27.03.2013 22:00, schrieb Antonio Vico:
>>> I reply to myself. I tested the plugin. Initially I thougth that work
>>> like a popup in openlayers and I do the answer for this.
>>> I visited this link that use qgis-web-client and show images in popup
>>> when cursor is over certains icons.
>>> http://webgis.uster.ch/maps/stadtentwaesserung/wc_anlagen?format=image/jpeg&visibleLayers=WC-Anlagen,Gemeindegrenze,Pixelkarten%20und%20%C3%9Cbersichtsplan&searchtables=&startExtent=692000,241500,700100,249000&maxExtent=692000,241500,700100,249000
>>> This is that I want to do. I think this is a modification in javascript
>>> in the openlayers files used in qgis web client but I don't know about
>>> javascript and can't do it
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> __________ Information from ESET Mail Security, version of virus
>>> signature database 8169 (20130327) __________
>>> The message was checked by ESET Mail Security.
>>> http://www.eset.com
>> http://www.eset.com
> signature database 8171 (20130328) __________
> http://www.eset.com
> __________ Information from ESET Mail Security, version of virus signature database 8171 (20130328) __________
> http://www.eset.com
http://www.eset.com
