[Qgis-user] SVG directory & SVG point fill styling
Andreas Neumann
a.neumann at carto.net
Fri May 3 06:51:01 PDT 2013
Yes - you could report a bug.
Personally I do not know if there are incompatibilities between 1.8x
and 2.0 in this respect.
Andreas
On Fri, 3 May 2013 13:50:17 +0100, Jonathan Moules wrote:
> Hi Andreas,
> Somehow I missed that (I did find the "plugins" one just above it
> though).
> While that does work, it seems my second issue is still occurring
> When I load the QML style created in 1.8.0, it's not applying the
> SVGs. Should I open a ticket for that?
> Thanks!
> Jonathan
> On 3 May 2013 13:41, Andreas Neumann wrote:
>> Hi Jonathan,
>> These are in Settings --> Options --> System --> Scroll down to
>> bottom "SVG Paths".
>> Andreas
>> On Fri, 3 May 2013 12:46:05 +0100, Jonathan Moules wrote:
>>> Hi List,
>>> In 1.8, I could have set a path somewhere that QGIS would read
>>> and be
>>> able to get its SVG files from. These would then be used with
>>> styling.
>>> Where is this in 1.9? I can't seem to find it and loading my QML
>>> now
>>> files fails.
>>> Further, if I put the files in
>>> Quantum GIS Weeklyappsqgis-devsvg
>>> They get picked up when symbolising styles, but they don't show
>>> as the
>>> fill.
>>> I'm using withe Warwickshire County Council styling as here -
>>> which
>>> worked fine in 1.8.0 and generated those QML files.
>>> What's going on here? Is 1.9 not backward compatible with 1.8 in
>>> regards to QML styles?
>>> Thanks,
>>> Jonathan
>>> This transmission is intended for the named addressee(s) only
>>> and may
>>> contain sensitive or protectively marked material up to
>>> RESTRICTED and
>>> should be handled accordingly. Unless you are the named addressee
>>> (or
>>> authorised to receive it for the addressee) you may not copy or
>>> use
>>> it, or disclose it to anyone else. If you have received this
>>> transmission in error please notify the sender immediately. All
>>> email
>>> traffic sent to or from us, including without limitation all GCSX
>>> traffic, may be subject to recording and/or monitoring in
>>> accordance
>>> with relevant legislation.
>> Andreas Neumann
>> Böschacherstrasse 10A
>> 8624 Grüt (Gossau ZH)
>> Switzerland
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org [1]
>> http://lists.osgeo.org/mailman/listinfo/qgis-user [2]
> This transmission is intended for the named addressee(s) only and
> may
> contain sensitive or protectively marked material up to RESTRICTED
> and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use
> transmission in error please notify the sender immediately. All email
> traffic, may be subject to recording and/or monitoring in accordance
> Links:
> [1] mailto:Qgis-user at lists.osgeo.org
> [2] http://lists.osgeo.org/mailman/listinfo/qgis-user
> [3] mailto:a.neumann at carto.net
Andreas Neumann
Switzerland
