[Qgis-user] SVG directory & SVG point fill styling
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Fri May 3 05:50:17 PDT 2013
Hi Andreas,
Somehow I missed that (I did find the "plugins" one just above it though).
While that does work, it seems my second issue is still occurring  When I
load the QML style created in 1.8.0, it's not applying the SVGs. Should I
open a ticket for that?
Thanks!
Jonathan
On 3 May 2013 13:41, Andreas Neumann <a.neumann at carto.net> wrote:
> Hi Jonathan,
> These are in Settings --> Options --> System --> Scroll down to bottom
> "SVG Paths".
> Andreas
> On Fri, 3 May 2013 12:46:05 +0100, Jonathan Moules wrote:
>> Hi List,
>> In 1.8, I could have set a path somewhere that QGIS would read and be
>> able to get its SVG files from. These would then be used with styling.
>> Where is this in 1.9? I can't seem to find it and loading my QML now
>> files fails.
>> Further, if I put the files in
>> Quantum GIS Weeklyappsqgis-devsvg
>> They get picked up when symbolising styles, but they don't show as the
>> fill.
>> I'm using withe Warwickshire County Council styling as here - which
>> worked fine in 1.8.0 and generated those QML files.
>> What's going on here? Is 1.9 not backward compatible with 1.8 in
>> regards to QML styles?
>> Thanks,
>> Jonathan
>>  This transmission is intended for the named addressee(s) only and may
>> contain sensitive or protectively marked material up to RESTRICTED and
>> should be handled accordingly. Unless you are the named addressee (or
>> authorised to receive it for the addressee) you may not copy or use
>> it, or disclose it to anyone else. If you have received this
>> transmission in error please notify the sender immediately. All email
>> traffic sent to or from us, including without limitation all GCSX
>> traffic, may be subject to recording and/or monitoring in accordance
>> with relevant legislation.
> Andreas Neumann
> Böschacherstrasse 10A
> 8624 Grüt (Gossau ZH)
> Switzerland
> ______________________________**_________________
> Qgis-user mailing list
> http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130503/8ef37744/attachment.html>
