[Qgis-user] SVG directory & SVG point fill styling
Andreas Neumann
a.neumann at carto.net
Fri May 3 05:41:04 PDT 2013
Hi Jonathan,
These are in Settings --> Options --> System --> Scroll down to bottom
"SVG Paths".
Andreas
On Fri, 3 May 2013 12:46:05 +0100, Jonathan Moules wrote:
> Hi List,
> In 1.8, I could have set a path somewhere that QGIS would read and be
> able to get its SVG files from. These would then be used with
> styling.
> Where is this in 1.9? I can't seem to find it and loading my QML now
> files fails.
> Further, if I put the files in
> Quantum GIS Weeklyappsqgis-devsvg
> They get picked up when symbolising styles, but they don't show as
> the
> fill.
> I'm using withe Warwickshire County Council styling as here - which
> worked fine in 1.8.0 and generated those QML files.
> What's going on here? Is 1.9 not backward compatible with 1.8 in
> regards to QML styles?
> Thanks,
> Jonathan
> This transmission is intended for the named addressee(s) only and
> may
> contain sensitive or protectively marked material up to RESTRICTED
> and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use
> it, or disclose it to anyone else. If you have received this
> transmission in error please notify the sender immediately. All email
> traffic sent to or from us, including without limitation all GCSX
> traffic, may be subject to recording and/or monitoring in accordance
> with relevant legislation.
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
