[Qgis-user] SVG directory & SVG point fill styling
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Fri May 3 04:46:05 PDT 2013
Hi List,
In 1.8, I could have set a path somewhere that QGIS would read and be able
to get its SVG files from. These would then be used with styling.
Where is this in 1.9? I can't seem to find it and loading my QML now files
fails.
Further, if I put the files in
\Quantum GIS Weekly\apps\qgis-dev\svg\
They get picked up when symbolising styles, but they don't show as the fill.
I'm using withe Warwickshire County Council styling as here - which worked
fine in 1.8.0 and generated those QML files.
What's going on here? Is 1.9 not backward compatible with 1.8 in regards to
QML styles?
Thanks,
Jonathan
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130503/c6f74242/attachment.html>
