[Qgis-user] Vector Graduaded Renderer triggers new classification
Andreas Neumann a.neumann at carto.net
Fri May 3 06:55:30 PDT 2013
 Hi Thomas,
 This is fixed in QGIS master (the soon to be released version 2.0). I
 do not believe that this will be fixed in version 1.8. Most developers
 currently work on the version 2.0.
 Andreas
 On Fri, 03 May 2013 13:42:05 +0200, Thomas Wahlmüller wrote:
> Hi all,
> I am trying to put the same layer style to different data columns
> with the new symbology (tested 1.8, 1.-268 on windows). I use the
> graduaded renderer - The problem is after changing the colunn a new
> classification is triggerd so the predefined colors and ranges are
> dropped.
> Is this behavior intended? If so, is there a way to let the symobl
> settings and ranges stay the same without editing the layer style
> file?
> thanks
> Thomas
> Qgis-user mailing list
 Andreas Neumann
 Böschacherstrasse 10A
 8624 Grüt (Gossau ZH)
 Switzerland
