[Qgis-user] Buffer with qgis : wgs84/mercator world?
Stéphane Henriod s at henriod.info
Fri May 10 03:46:10 PDT 2013
Hi
I assume there is a misundersanding. I guess Jo assumed that your data is
stored in a PostGIS database, which is why he advised to cast the
coordinates as GEOGRAPHY.
As you seem to be working with shapefiles, this actually doesn't concern
you.
I would project my data into pseudo-mercator (EPSG:3857) in order to have
meter-based coordinates. But I am not sure it will give you the most
accurate resutls (don't know how it distorts the surface).
How precise does your buffer need to be? If you work on such a small scale
(Berlin - Beijing). I would assume that you don't really care about small
distortions, do you?
Cheers
Stéphane
"Le mot progrès n'aura aucun sens tant qu'il y aura des enfants malheureux"
-- Albert Einstein
"A journey does not need reasons. Before long, it proves to be reason
enough in itself. One thinks that one is going to make a journey, yet soon
it is the journey that makes or unmakes you." -- Nicolas Bouvier
Photos de voyages, photos de montagne: http://www.henriod.info
On Fri, May 10, 2013 at 12:06 PM, image <lcelati at latitude-geosystems.com>wrote:
> Hello,
> Thank you for your reply. But sorry i do not really understand. Could you
> make explicit please?
> What do you understand by 'geography'?
> I just make a new test with world mercator & wgs84 also and the result of
> the buffers are always big circle . So i suppose that the unity is
> radians/degrés...
> My raw linear shp is very long. It is a corridor from Berlin to Beijing.
> According to you, which coordinate system i should select in order to
> generate a buffer (20kms)?
> Thank you.
> http://osgeo-org.1560.x6.nabble.com/Buffer-with-qgis-wgs84-mercator-world-tp5052504p5052521.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130510/e9067680/attachment.html>
