[Qgis-user] Buffer with qgis : wgs84/mercator world?
Marco Lechner - FOSSGIS e.V.
marco.lechner at fossgis.de
Fri May 10 04:36:20 PDT 2013
HI image,
the "meters" in Pseudo Mecator or Google Mercator are not exact meters
in reality. Use a better metric projected CRS available for your region
of work (where is your data located). You could use the UTM (e.g. 32632
if in Germany) to get far better results.
Marco
P.S. in Google Mercator the "meters" only next to the equator are
approximately meters
Am 10.05.2013 13:09, schrieb image:
> Thank you.
> I just tried a test to generate a buffer 20 meters from my linear shp(with
> pseudo mercator). It works. But when i measure, the buffer is not to 20
> meters but 12/14 meters.
> Could you just make a quick test on your side please?
> Via the interface called Buffer i have entered those parameters:
> Segments for approximation (by default) : 5
> Buffer distance : 20
> Indeed i'm working on such a small scale and i don't care about small
> distortions.
> Could you throw light for me?
> Thanks.
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Buffer-with-qgis-wgs84-mercator-world-tp5052504p5052535.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
FOSSGIS 2013, Die Konferenz für Open Source GIS mit OpenData und OpenStreetMap erstmals in der Schweiz!
12.-14. Juni, HSR, Rapperswil, http://www.fossgis.de/konferenz/2013/
FOSSGIS e.V.
die unabhängige Hilfe bei freier GIS-Software und freien Geodaten
