[Qgis-user] kriging problems
Victor Olaya volayaf at gmail.com
Sun May 12 13:25:15 PDT 2013
it seems you are using an older verion of SEXTANTE. Those lines in
your error trace were changed in february 1st, according to the git
log... Whether you have an old master version, or you have some other
version of SEXTANTE that is being loaded instead of the current one. I
would recommend you to delete the
'/home/matteo/.qgis2/python/plugins/sextante' folder in your computer,
since that is likely to be an older version, installed separately from
master.
regards
2013/5/10 matteo <matteo.ghetta at gmail.com>:
> Hi all,
> I work with QGIS 1.9 and I noticed a problem with the Sextante-Saga kriging
> functions.
> Starting QGIS and without any layers loaded, there aren't problem with the
> four kriging funcions. But loading some layers (even only one point layer) a
> python error occurs:
> Errore durante l'esecuzione di codice Python:
> Traceback (most recent call last):
>   File "/home/matteo/.qgis2/python/plugins/sextante/gui/SextanteToolbox.py",
> line 138, in executeAlgorithm
>     dlg = ParametersDialog(alg)
>   File
> "/home/matteo/.qgis2/python/plugins/sextante/gui/ParametersDialog.py", line
> 43, in __init__
>     self.paramTable = ParametersPanel(self, alg)
>   File "/home/matteo/.qgis2/python/plugins/sextante/gui/ParametersPanel.py",
> line 74, in __init__
>     self.initGUI()
> line 116, in initGUI
>     widget = self.getWidgetFromParameter(param)
> line 257, in getWidgetFromParameter
>     item.addItems(self.getFields(layers[0], param.datatype))
> line 325, in getFields
>     for idx, field in fieldMap.iteritems():
> AttributeError: 'QgsFields' object has no attribute 'iteritems'
> Versione Python:
> 2.7.3 (default, Aug  1 2012, 05:27:35)
> [GCC 4.6.3]
> Versione di QGIS:
> 1.9.0-Master Master, exported
> Percorso Python: ['/home/matteo/.qgis2/python/plugins/sextante_taudem',
> '/home/matteo/.qgis2/python/plugins/sextante', '/usr/share/qgis/python',
> '/home/matteo/.qgis2/python', '/home/matteo/.qgis2/python/plugins',
> '/usr/share/qgis/python/plugins', '/usr/lib/python2.7',
> '/usr/lib/python2.7/plat-linux2', '/usr/lib/python2.7/lib-tk',
> '/usr/lib/python2.7/lib-old', '/usr/lib/python2.7/lib-dynload',
> '/usr/local/lib/python2.7/dist-packages',
> '/usr/lib/python2.7/dist-packages', '/usr/lib/python2.7/dist-packages/PIL',
> '/usr/lib/python2.7/dist-packages/gst-0.10',
> '/usr/lib/python2.7/dist-packages/gtk-2.0', '/usr/lib/pymodules/python2.7',
> '/usr/lib/python2.7/dist-packages/ubuntu-sso-client',
> '/usr/lib/python2.7/dist-packages/ubuntuone-client',
> '/usr/lib/python2.7/dist-packages/ubuntuone-control-panel',
> '/usr/lib/python2.7/dist-packages/ubuntuone-couch',
> '/usr/lib/python2.7/dist-packages/ubuntuone-installer',
> '/usr/lib/python2.7/dist-packages/ubuntuone-storage-protocol',
> '/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode',
> '/home/matteo/.qgis2/python/plugins/mmqgis/forms',
> '/usr/share/qgis/python/plugins/fTools/tools']
> Ideas? Is it a bug or have these functions a conflict with some path?
> Cheers,
> Matteo
> Qgis-user mailing list
