[Qgis-user] kriging problems
Victor Olaya
volayaf at gmail.com
Mon May 13 00:49:55 PDT 2013
could you send the log file to see what is happening? it should be in
your home folder in qgis2/sextante
Enable the 'log console output' in the SEXTANTE/SAGa configuration and
try to run a SAGA algorithm before sending it, so the problems gets
logged.
Thanks in advance!
2013/5/13 matteo <matteo.ghetta at gmail.com>:
> Il 13/05/2013 09:36, Victor Olaya ha scritto:
>> I guess that the new version of SEXTANTE that now QGIS is using, might
>> not be configured correctly. Go to the SEXTANTE configuration and see
>> if everything is fine.
> I check under sextante configuration, but it seems fine.
> Maybe there are just some troubles for the kriging functions.
> Matteo
