[Qgis-user] kriging problems
matteo
matteo.ghetta at gmail.com
Mon May 13 01:00:06 PDT 2013
Il 13/05/2013 09:49, Victor Olaya ha scritto:
> could you send the log file to see what is happening? it should be in
> your home folder in qgis2/sextante
> Enable the 'log console output' in the SEXTANTE/SAGa configuration and
> try to run a SAGA algorithm before sending it, so the problems gets
> logged.
> Thanks in advance!
That's the log file when the folder without moving the sextante folder
from .qgis2/python/plugin (when I try to launch the kriging function):
Started logging at lun mag 13 2013 09:53:04
ERROR|lun mag 13 2013 09:53:04|Could not load model
watersheds.model|ALGORITHM:ftools:export/addgeometrycolumns
ERROR|lun mag 13 2013 09:53:21|Could not load model
And this is the log after I moved away the sextante folder (always
trying to launch a kriging algorithm):
ERROR|lun mag 13 2013 09:56:08|Could not open GRASS algorithm:
/usr/share/qgis/python/plugins/sextante/grass/description/r.stream.stats.txt|OutputFile|outputtext
r.stream.stats.txt
Started logging at lun mag 13 2013 09:56:08
ALGORITHM|lun mag 13 2013
09:56:16|sextante.runalg("saga:thiessenpolygons","/usr/share/qgis/python/plugins/sextante/tests/data/points.shp",None)
INFO|lun mag 13 2013 09:56:16|SAGA execution commands|libshapes_points
"Thiessen Polygons" -POINTS
-POLYGONS
"/tmp/sextante/sagathiessenpolygonsc604bd18042d41f084e676c1ba6d2185.shp"
INFO|lun mag 13 2013 09:56:17|SAGA execution console output||error:
module not found [Thiessen Polygons]||error:
module|_____________________________________________|##### ## #####
##|_____________________________________________|||executable
modules:|0 - Convert Table to Points|1 - Count Points in
Polygons|2 - Create Point Grid|3 - Distance Matrix|4 - Fit N
Points to shape|5 - Convert Lines to Points|6 - Add Coordinates to
points|7 - Remove Duplicate Points|8 - Clip Points with
Polygons|9 - Separate points by direction|10 - Add Polygon
Attributes to Points|11 - Points Filter|12 - Convex Hull|14 -
Points Thinning||type -h or --help for further information
Cheers,
Matteo
