[Qgis-user] Antw: Re: Issues with Print Composer and QGIS Server
Jan David Bendrien jandavid.bendrien at iwes.fraunhofer.de
Tue May 14 03:55:14 PDT 2013
>> 1. The QGIS Server apparently does not load images in print templates
>> relative to the location of the .qgs-file, but relative to the location of
>> the cgi-bin-executable. So we have to put our images in a subfolder of
>> cgi-bin.
> Can you define an absolute path for the images
No, not easily. We are creating the .qgs-file on a windows system and copy it over to the unix server.
> 2. Is there a fix for this: When we define a grid in QGIS Desktop, nothing
> is shown in the pdf (or, if labelling is active, sometimes, only one lonely
> zero below the map). There is no grid.
> It would be good to know, which version of QGIS Server you are using.
Sorry. We are using QGIS Server 1.8. I've had a look in the .qgs file. Here is the section about the grid:
<Grid gridStyle="0" crossLength="3" penColorRed="0" penColorBlue="0" intervalX="1" offsetX="0" intervalY="1" offsetY="0" show="1" penWidth="0.4" penColorGreen="0">
			    <Annotation direction="0" precision="0" position="1" frameDistance="1" show="1" font="Arial,8,-1,5,50,0,0,0,0,0"/>
</Grid>
View this message in context: http://osgeo-org.1560.x6.nabble.com/Antw-Re-Issues-with-Print-Composer-and-QGIS-Server-tp5053118.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130514/55936ded/attachment.html>
