[Qgis-user] Adding GRASS Vector layer
Kurt Springs ferret_bard at mac.com
Tue May 14 14:12:39 PDT 2013
I'm not sure about "right."  I have to use data that comes off of two different projections systems, therefore two different folders, which I have done before.  In fact, the map I'm working on is already using different folders for the raster DEMs and the Vector rivers, lakes, and ocean.  They are all in my grassdata folder under my home directory.
Kurt
On May 14, 2013, at 4:45 PM, Alfonso Flaquer wrote:
> Maybe is a dumb question, but did You set the right grass folder in qgis?
> AfLa
> El 14-05-2013, a las 15:01, Kurt Springs <ferret_bard at mac.com> escribió:
>> Hi all,
>> I am trying to add a point vector layer from GRASS to my QGIS map.  The GRASS layer was generated from a an ascii file, and I could see the points in GRASS.  When I went to import into QGIS it says "No layers available in this map."  I know I've done this before.  Anyone have any ideas on what's wrong, and more importantly, how to fix it?
>> I generated the vector layers on GRASS 7.0 and am using William Kyngesburye's QGIS 1.8.0-2 on my OS X 10.7.5 Lion.
>> Kurt
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
