[Qgis-user] Adding GRASS Vector layer
Paulo van Breugel p.vanbreugel at gmail.com
Tue May 14 23:31:48 PDT 2013
I don't know about OSX, but on Linux GRASS GIS 7.0 is not yet supported in QGIS (grass-gdal plugin is not yet working I believe). Try if a vector layer in GRASS 6.4 works.
Sent from Samsung tabletKurt Springs <ferret_bard at mac.com> wrote:I'm not sure about "right."  I have to use data that comes off of two different projections systems, therefore two different folders, which I have done before.  In fact, the map I'm working on is already using different folders for the raster DEMs and the Vector rivers, lakes, and ocean.  They are all in my grassdata folder under my home directory.
Kurt
On May 14, 2013, at 4:45 PM, Alfonso Flaquer wrote:
> Maybe is a dumb question, but did You set the right grass folder in qgis?
> AfLa
> El 14-05-2013, a las 15:01, Kurt Springs <ferret_bard at mac.com> escribió:
>> Hi all,
>> I am trying to add a point vector layer from GRASS to my QGIS map.  The GRASS layer was generated from a an ascii file, and I could see the points in GRASS.  When I went to import into QGIS it says "No layers available in this map."  I know I've done this before.  Anyone have any ideas on what's wrong, and more importantly, how to fix it?
>> I generated the vector layers on GRASS 7.0 and am using William Kyngesburye's QGIS 1.8.0-2 on my OS X 10.7.5 Lion.
>> Kurt
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130515/56bedea0/attachment.html>
