[Qgis-user] Issues with Print Composer and QGIS Server
Andreas Neumann
a.neumann at carto.net
Wed May 15 03:01:27 PDT 2013
Are you testing from QGIS Web Client? And are your units in degrees?
If yes, there is a problem that the grid interval is kind of hard-coded
in the file "site/scripts/QGISExtensions.js" - search for
"grid_interval". This is only optimized for meters.
One need to fix this issue for degree based units or make it
user-defineable in GlobalOptions.js - you can issue a bug/feature
request for this in hub.qgis.org.
Sorry about that - initially this was only for our inhouse purpose
where we do not deal with degree-based projection systems.
Andreas
On Wed, 15 May 2013 02:37:45 -0700 (PDT), Jan David Bendrien wrote:
> Hello Marco,
>>>2. Is there a fix for this: When we define a grid in QGIS Desktop,
>>> nothing
>>>is shown in the pdf (or, if labelling is active, sometimes, only one
> lonely
>>>zero below the map). There is no grid.
>> Try a newer version.
> We did this. We are running QGIS Server 1.9 including all changes up
> to
> 13.5.2013.
> But the problem persists.
> Greetings,
> Jan David
> http://osgeo-org.1560.x6.nabble.com/Issues-with-Print-Composer-and-QGIS-Server-tp5053093p5053351.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
