[Qgis-user] Issues with Print Composer and QGIS Server
Jan David Bendrien jandavid.bendrien at iwes.fraunhofer.de
Wed May 15 03:09:30 PDT 2013
Hi Andreas,
> Are you testing from QGIS Web Client? And are your units in degrees?
yes. yes.
> If yes, there is a problem that the grid interval is kind of hard-coded
> in the file "site/scripts/QGISExtensions.js" - search for
> "grid_interval". This is only optimized for meters.
Aah. This might be the answer. I will check this soon.
> One need to fix this issue for degree based units or make it
> user-defineable in GlobalOptions.js - you can issue a bug/feature
> request for this in hub.qgis.org.
If this is indeed the problem, I can submit a bug report.
Greetings,
Jan David
View this message in context: http://osgeo-org.1560.x6.nabble.com/Issues-with-Print-Composer-and-QGIS-Server-tp5053093p5053361.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
