[Qgis-user] delete field doesn't work
Alexandre Neto senhor.neto at gmail.com
Thu May 16 02:47:34 PDT 2013
In 1.7.4 I don't know, but in 1.8 it works like expected. In edit mode,
pressing "Delete Column" will give a list of all columns of the layer,
which one can select.
It happens with that specific shapefile, or any shapefile?
Alexandre Neto
On Thu, May 16, 2013 at 10:38 AM, matteo <matteo.ghetta at gmail.com> wrote:
> Il 16/05/2013 11:30, Giacomo Rossi ha scritto:
>  Hello,
>> I've loaded one shapefile in qgis 1.7.4 but in the attribute table I
>> don't manage to push the button "delete field". How can I solve this
>> problem?
>> Thank you
>> Best regards
> I think that this features is not implemented in the 1.7 and in the 1.8
> version. But you can download the table manager plugin to add/delete and
> modify columns.
> Cheers,
> Matteo
> ______________________________**_________________
> Qgis-user mailing list
> http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130516/d074ba8b/attachment.html>
