[Qgis-user] delete field doesn't work
Giacomo Rossi
giacomo.rossi85 at gmail.com
Thu May 16 02:48:36 PDT 2013
With every shp...
2013/5/16 Alexandre Neto <senhor.neto at gmail.com>
> In 1.7.4 I don't know, but in 1.8 it works like expected. In edit mode,
> pressing "Delete Column" will give a list of all columns of the layer,
> which one can select.
> It happens with that specific shapefile, or any shapefile?
> Alexandre Neto
> On Thu, May 16, 2013 at 10:38 AM, matteo <matteo.ghetta at gmail.com> wrote:
>> Il 16/05/2013 11:30, Giacomo Rossi ha scritto:
>> Hello,
>>> I've loaded one shapefile in qgis 1.7.4 but in the attribute table I
>>> don't manage to push the button "delete field". How can I solve this
>>> problem?
>>> Thank you
>>> Best regards
>> I think that this features is not implemented in the 1.7 and in the 1.8
>> version. But you can download the table manager plugin to add/delete and
>> modify columns.
>> Cheers,
>> Matteo
>> ______________________________**_________________
>> Qgis-user mailing list
>> http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130516/38b6a246/attachment.html>
