[Qgis-user] saga & sextante
Victor Olaya volayaf at gmail.com
Thu May 16 05:20:03 PDT 2013
The idea is that now you do not need to install SAGA separately, and
it should automatically be configured to that folder (unless, like in
your case, you had already configured it manually).
There must be some problem with the packed SAGA. Change the link the
to your old one if you want to have a working version while we fix
this
thanks for the report
Victor
2013/5/16 skampus <stefano.campus at regione.piemonte.it>:
> i have just updated qgis dev to 280 version and i see that saga is packaged
> and downloaded in osgeo4w, so a folder called C:\OSGeo4W\apps\saga is
> created.
> but if i change the path of saga folder, in sextante "option and
> configuration", adding this "new" saga path, nothing works, because it says
> that C:\OSGeo4W\apps\saga \saga_cmd.exe is not a win32 valid executable file
> (more or less, the message is in italian).
> do i have to keep the "old" link to saga folder?
> View this message in context: http://osgeo-org.1560.x6.nabble.com/saga-sextante-tp5053663.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
