[Qgis-user] saga & sextante
MORREALE Jean Roc
jr.morreale at enoreth.net
Thu May 16 05:45:21 PDT 2013
I confirm this report on a clean osgeo4w install and a qgis installation
with the default parameter.
Le 16/05/2013 14:20, Victor Olaya a écrit :
> The idea is that now you do not need to install SAGA separately, and
> it should automatically be configured to that folder (unless, like in
> your case, you had already configured it manually).
> There must be some problem with the packed SAGA. Change the link the
> to your old one if you want to have a working version while we fix
> this
> thanks for the report
> Victor
> 2013/5/16 skampus <stefano.campus at regione.piemonte.it>:
>> i have just updated qgis dev to 280 version and i see that saga is packaged
>> and downloaded in osgeo4w, so a folder called C:\OSGeo4W\apps\saga is
>> created.
>> but if i change the path of saga folder, in sextante "option and
>> configuration", adding this "new" saga path, nothing works, because it says
>> that C:\OSGeo4W\apps\saga \saga_cmd.exe is not a win32 valid executable file
>> (more or less, the message is in italian).
>> do i have to keep the "old" link to saga folder?
