[Qgis-user] Raster resample data during display
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Fri May 17 05:21:05 PDT 2013
Hi Antonio,
  In my 1.9.0-19 build, double click on the raster, then go to the "style"
tab. At the very bottom there's a "resampling" section which lets you
choose which algorithm to use, when to use it (zoomed in/out) and an
"oversampling" thing (not sure what that does).
Actually looks better than the ArcGIS version.
Regards,
Jonathan
On 16 May 2013 22:58, Antonio Locandro <antoniolocandro at hotmail.com> wrote:
> I already have dev installed can you point where the option is?
> **Thanks
> *Ing. Antonio Locandro*
> Tegucigalpa, Honduras
> Date: Thu, 16 May 2013 18:31:11 +0200
> Subject: Re: [Qgis-user] Raster resample data during display
> From: anitagraser at gmx.at
> To: antoniolocandro at hotmail.com
> CC: qgis-user at lists.osgeo.org
> Yes, that's implemented in the current developer version which will be
> released as QGIS 2.0 in June.
> Best wishes,
> Anita
> On Thu, May 16, 2013 at 5:12 PM, AntonioLocandro <
> Is there an option to do this in QGIS? In other COTS you can do this when
> you
> input raster and the data is of continuous form you can change it for
> display like Nearest Neighbor, Cubic Convolution, etc
> http://osgeo-org.1560.x6.nabble.com/Raster-resample-data-during-display-tp5053730.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130517/412271a6/attachment.html>
