[Qgis-user] Raster resample data during display
Antonio Locandro antoniolocandro at hotmail.com
Fri May 17 14:36:51 PDT 2013
Found it! thanks, didnt notice the overflow of the information first, the dialog was big. Do you happen to know if you can have on the fly hillshade effect?
Ing. Antonio Locandro
Tegucigalpa, Honduras
Date: Fri, 17 May 2013 13:21:05 +0100
Subject: Re: [Qgis-user] Raster resample data during display
To: antoniolocandro at hotmail.com
CC: anitagraser at gmx.at; qgis-user at lists.osgeo.org
Hi Antonio,  In my 1.9.0-19 build, double click on the raster, then go to the "style" tab. At the very bottom there's a "resampling" section which lets you choose which algorithm to use, when to use it (zoomed in/out) and an "oversampling" thing (not sure what that does).
Actually looks better than the ArcGIS version.Regards,Jonathan
On 16 May 2013 22:58, Antonio Locandro <antoniolocandro at hotmail.com> wrote:
I already have dev installed can you point where the option is?
Thanks
Date: Thu, 16 May 2013 18:31:11 +0200
CC: qgis-user at lists.osgeo.org
Yes, that's implemented in the current developer version which will be released as QGIS 2.0 in June.
Best wishes,
Anita
On Thu, May 16, 2013 at 5:12 PM, AntonioLocandro <antoniolocandro at hotmail.com> wrote:
Is there an option to do this in QGIS? In other COTS you can do this when you
input raster and the data is of continuous form you can change it for
display like Nearest Neighbor, Cubic Convolution, etc
View this message in context: http://osgeo-org.1560.x6.nabble.com/Raster-resample-data-during-display-tp5053730.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130517/ac83c0b5/attachment.html>
