[Qgis-user] documentation for clip_shp_to_shp
Werner Macho werner.macho at gmail.com
Tue May 21 03:40:43 PDT 2013
Hi Silver!
Beside the fact that your script is not related to QGIS ..
the script is to be copied within the shapefiles in the directory and to be
called from there.
The only thing you need to set is
shpclip = "/home/thomas/git/python_scripts/clipping_area.shp"
thats the path to your shape that you take for clipping ..
everything else should run out of the box ..
the created shapefiles will hae a suffix _clip with their name ..
Or i missunderstood you and you wanted to try to program it for the QGIS
Python Console ..
kind regards
Werner
On Tue, May 21, 2013 at 12:29 PM, Silver Ashen <silver.ashen at gmail.com>wrote:
> Hello everybody,
> I'm new on the mailing list. I'm a beginner with Python and Python Console
> in QGIS.
> I have a lot of shapefiles that I want to clip with one shapefile. Instead
> of doing it manually, I want to try to use a script to do it.
> By seeking on the mailing list archives, I found this :
> http://osdir.com/ml/qgis-user-gis/2011-05/msg00122.html
> This is very useful but I definitely do mistakes in filling the different
> part of the code. Plus, I don't understand every parameters (pref, suf ??).
> Do you know where I can find some accurate documentation on
> clip_shp_to_shp with examples ?
> Where is the description of the Glob module ?
> Thanks for your support.
> Bye.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130521/7b952c37/attachment.html>
